I researched this not long ago, and I am 90% sure that the limited slip that is available for the rear of the 80 series is a wear item that is not rebuildable.
A contact person at Auburn informed me the original Auburn Pro-Series for 80 series was made in Japan
...the Auburn is quite a bit more unpredictable in low traction conditions than putting a full automatic locker in the rear. It is a lot less effective offroad and in especially in winter conditions where the slip/engagement process will cause the rear to kick out under throttle.
So don't fear the rear locker. It is superior in every way and the parking lot clicking will reassure you that it's there.
Thanks for the feedback, Nay. That's another option I considered but had started to rule out due to road manners. I'm surprosed that the autolocker was more civilized than the Auburn, considering they do basically the same thing but the autolocker stated from locked and is either fully locked or fully slipping and the LSD started from the middle and varies in both directions (to and from locked, but never fully)
Perhaps my best option is to start with an Aussie and see how I like it. If it feels good as a DD, I can add the TrueTrac in the front. If I don't like it I can replace it with the Auburn or just go back to open. Hmmm....
I ran Auburns front and rear in my Dodge ramcharger for many years. 4" lift, 35", and granny 4 speed and it would tear up the rubicon. Other people thought it had lockers. Are they good? Damn right! Are they locker good? No but with some learning of the necessary driving style they will impress. They also have a "Pro" line of LSD's. Not sure if they sell one for the 80.
I think auto lockers suffer from carryover bias of people using them in 90" wheelbase CJ7s and there's a fear of messing up daily drivability. I finally just said screw it and never regretted the locker for a second - it was 100% upside. But as a wise man sayeth, "know thyself".
If it were me, I'd Aussie the rear diff and then see what you think you need. I'd only add a front trutrac for winter reasons as it won't make all that much difference in offroad situations that have overwhelmed a locked center and rear diff in low range. In that case, a front locker is everything and LSDs just don't cut it.
Kind of an older thread but figured i'd chime in. I have a 1990 jdm 80, and it has rear LSD which I assume is factory. So far it has been good, haven't had an instance yet where I thought, damn i wish I had a locker...mind you I have no idea how worn it is
I have TrueTrac's in front and rear of my 96 Bronco.
I'm not 100% sure, but I think it's a clutch type, I did the research 4 or so yrs ago and thats the answer that's ringing in my brain...now that i'm thinking about it 350k kms and 27 yrs later i'm betting the clutches probably aren't grabbing like they should anymore..Is it a torsen or clutch type?
