Even more reason to run aftermarket arms with a three inch lift.
Do you remember what thread that was so I can reference it?1.74 per inch is close enough for our needs and I corrected pinheads post at that time to correct for out trucks construction.
But you would still need to be conscience of pinion angles to combat drive line vibrations.
If you correct for caster beyond 4" of lift with arms or frame brackets you will have drive line angles that will cause severe vibrations.
The only way to maintain AWD and factory caster without vibrations is to do the frame drop and a cut and turn. Since a cut and turn has the same limitations as caster plates you would basically equate that to compensating for 4" of the lift and make the rest up with the frame drop. But you would still need to be conscience of pinion angles to combat drive line vibrations.
Or go part time. Which is ok provided you don't need H4 for any length of time.
Edit
meant to type winching, but as you can see by the factory side steps, there's definitely some wincing involved too![]()
The Mud world would appreciate you letting us know how your rig drives and the castor numbers with the new set up.I winced at that pic too!
I have 3" (75MM) Slinky HD springs on order and Slee control arms on their way. Getting rid of my OME 850/863 springs and I'll be running Icon shocks front and rear. According to Slee the arms are made for their 6" lift and give about 8 degrees of measured caster change. With my current lift and one inch spacers in the front and the OME bushings, my caster is currently at 0 and my truck feels darty at freeway speeds. I'm thinking I'll end up with about 5-6 degrees of positive caster with this set up. I'll get an alignment done and report back when it's all together.
8+3=11Here is a chart I found that is consistent with what has been written above posts.
I have been mulling over this in my mind and I don’t believe that if one added Slee arms to already installed castor plates the two mods would add up. My reasoning may be off but if the plates have already adjusted 4*, the arms will simply finishing bringing the 7* or whatever the arm manufacture claims castor increase will be with the arm alone.This is actually turning into a great thread keep it comin guys.
I had the OME yellow caster bushing plus the MAF drop bracket & it drove like a dream. I figure I was at around +5* derees. Since then I have stock bushings in there & I want my 5* degrees of caster back.
Last time I checked Slee arm correct 11* degrees8+3=11
you'd gain 1/4 at most, and have compromised bushing life and flex
Are you still running a 10” shock with the longer Flexi coil springs???
Interesting remark.
So, for a 3-4" lift you think an 11" travel shock is not a good idea? Should be less than that?
Peeps spend lots of money creating other lots of money problems, too long shocks usually leading the way.
