maxamillion2345
Franken-80
- Thread starter
- #41
Thanks guys I appreciate that! Damn decent of ya.
New Fan Clutch | 192900 | 2/5/15 |
Timing Belt, Timing Belt Tensioner, Serpentine, Upper Rad Hose, Thermostat, Water Pump | 199000 | 6/26/15 |
BFG KO2 265/75R16 | 220450 | 10/4/16 |
New Spark Plugs | 221550 | 10/28/16 |
New brake pads and rotors -- front and rear, New Front Calipers, New Front Wheel Seals, New driver side sway bar link, | 234800 | 10/11/17 |
New Napa battery | ??? | 1/8/18 |
New front brake pads and rotors | 250602 | 3/11/19 |
New Air Filter | 256108 | 6/21/19 |
New Radiator, New upper rad hose | 257756 | 8/21/19 |
New #6 ignition coil and spark plug | 264075 | 1/16/20 |
Well well well
I would rather have a 2003-2005 over a 2006/2007 for reliability. And obviously any of those years over 1998-2002 for the a750f but prices are rough in the later years still.
IMO, also, the Lexus looks better and you can ditch the AHC when it breaks
And... Night View. If you have to ask, you're not ready.
Air injectionWhat makes the later trucks less reliable?
Fortunately I passed and found a much better maintained one!High miles is no problem but it does not look in a good shape, looks like brakes, suspension, and real diff are leaking. I'd stay away.
Mine has 325k miles and I'd drive it to NYC and back now.
Needs some work but nothing major and the price is right. Exterior is in decent shape. T's look good, O-ring near thermostat housing not so good. I have 8 spare ignition coils after changing mine. You are welcome to one or two if needed.
I paid 3k for mine in a little rougher condition- ac doesnt work, bad tires, shocks rusted apart, steering rack/pump whine, rough interior. So i'd say you did pretty well.
edit: should add it had 296k on it when i bought it. Just rolled 298k
