Builds An Accidental Frame Off.................. (1 Viewer)
honestly you don't even need to buy self tappers, theyre kinda pricey these days, I just used drywall screws, should do the trick.... I guess were not going to see pictures of you polishing your shaft now
The input bearing on the t case, the one that the output shaft of the tranny rides on.
Seems like it may have spun at some point over the last half-a-hundred years.
Chatted with tech support from @cruiseroutfit for a while regarding this. Came up with a solid plan B.
Getting some stuff back together over the last few weeks.
Sometimes you just gotta get shady.
Trimmed the remaining parts of the shims off.
Then the local ski resort opened.
I would have taken a good automatic center punch to the exterior of that bearing and done a strike every 1/4" or so around the circumference in even number total (keeps it centered) in like 5 or 6 concentric rows then used that "juice" for added grip besides the little points created by the sharp center punch as I pounded thee bearing in.
That was discussed with tech help also.
In the end I decided to go with an extra .004 of shim stock and the retaining compound.
The path of least resistance first.
That looks like a super well-executed job!
I'm curious, how did you cut off the excess shim stock so cleanly?
Being as that shim stock was only .001" I just used a fresh razor blade and sliced it as deep into the space as I could get it.
Still going the wrong way.
