- Thread starter
- #61
Resistance came to mind seeing low range of spec on multimeter and when new battery seemd to solve the issue. Fresh battery maybe temporarily masking the issue. Time will tell. I think pressure testing the FP would show its health more effectively.
I hadn't any FP issues, but did have intermittent fuel sender issue giving faulty gauge readings. I pulled and replaced the sender and preventatively changed the fuel pump while I was in there (@195k miles).
HAHA!Thats stock wiring wrap- its not been repaired as far as I can tell. It has foam under the tape to insulate/protect the wires going into each side of the connector.
I dont see any reason to disconnect that plug to work on the fuel pump. You can remove negative batt cable if your concerned. If you still wish to remove it read on. I just did this a few days ago.
Ok the connector on mine was a Mo-Fo to get apart; you're not alone. Between dirt and sand falling into my eyes and mouth and trying not to break a wire or the mounting tab, I fiddled with it for 10min. Spray it off liberally with some maf or electrical cleaner because small debris or pebbles get lodged under the release tab. Push down the tab and try to walk the connector off, also there are two small nubs on either side of the connector towards the end, these lock the connector into place. You can gently use a pick too to release the connector off the nub and maybe walk the other side off. Just be gentle- its 15+years old and brittle- you dont want to create a new problem.
May the force be with you
I was told, and read in the history that there was a wire repair somewhere, so I thought this may be it. The wire repair may have been at the rear window defroster though, because that was also mentioned.
Not sure what fuel pump was installed, but since it was at a Toyota dealer I assume it was OE.
