After reading a couple post on ABS delete on the 80 series I decided to give it a go. Before taking the ABS unit out I did run a test to see if deleting the ABS did actually make a significant difference. Before I tested the brakes with the ABS system I used the Motive power bleeder and bled the brake system. I ordered the power bleeder from Amazon for $58. I also liked the clear bleeder bottle with magnet.
Motive Products 101 Power Bleeder
Genesis Magnet Bleeder Bottle
My 80 series brake system is basically stock but many other parts are not. I’m running the Slee 4 inch lift and also installed the stainless steel brake lines. I’m rolling on 35’s. I typically carry quite a few tools in my heavy drawer system and have the 14 gallon factory subtank installed, heavy bumpers, winch etc…. Basically, It’s a big heavy Land cruiser and the brakes, with abs, are not great if you need to stop in a hurry.
I ran my 1997 80 series up to 50mph and pushed the brake pedal as hard as I could. It seemed like it took forever to stop. I got out and measured the distance and it took 95 feet to stop. I ran it a couple more times (feeling I could do better) and came up with the same result. Thinking that the brakes could fade a bit after repeated use I came back on a different day and stomped on the brakes, but still had the same result. The best stop I pulled off was 95ft.
I took a look at ABS delete posts by jcordona1 and Jeepinpete and began taking things apart. It was a very straightforward process thanks to the previous posts. From start to finish it took about three hours. Thirty minutes of that time was spent getting the LSPV valve removed. The gas tank hinders access to the bolts a little bit.
Once the ABS delete was complete I used the power bleeder and got all the bubbles out of the system. The power bleeder is a great tool. It’s so nice to bleed the brakes so quickly.
Once everything was done I went up to the same location and slammed on the brakes. I had my daughter stand in a different spot to catch the stop a little better. I also put a blue bucket on the curb to note the 95ft mark foot from the previous test.
With the ABS system removed I was able to get stopped in 61 feet.
As soon as I drove after removing the ABS I noticed a big difference in the brakes. I’m very happy with this modification and also glad others posted great write ups and pictures to make the process easier.
Video Link
Video Link
