Registry 8x Series V8 Swaps (13 Viewers)
Sorry. That wasn't how I meant it.
I meant if you just base a build off the parts you have laying around it can take the level of your project down. That's what I meant by "found art project".
I may not be 100% innocent. 🤪
Just want to bump my DD tach box question. Anyone do a new one lately with the blue tooth? Just curious what wire you used for the input to the dash. I’ve tried two so far. From the igniter plug and from a splice near the glove box. No luck so far.
I had to replace the lock position switches that are on the diffs and t-case. I believe they are notorious for failing over time. If you look for a Land cruiser one they are expensive but for toyota parts, they also cross reference to a tacoma part for cheap. I did not get a rebuild kit for the t-case motor, I had to just open it up and clean it and "sand" resurface the armature and stator contacts and re-grease. Good as new.
I misunderstood when you said switches. I have replaced mine with the cheaper Tacoma sensors, as for the T case motor I had probably better do the same before I put my trans in tomorrow morning. thank you for the reply
We’ll defineu out power to the motor and all before you install to verify it works.
Just want to bump my DD tach box question. Anyone do a new one lately with the blue tooth? Just curious what wore you used for the input to the dash. I’ve tried two so far. From the igniter plug and from a splice near the glove box. No luck so far.
93-94 is totally different from 95-97. What year?
I recommend an oscilloscope to troubleshoot DD products since they don't have diagnostics.
Any suggestions on what type of material to use?
I'll elaborate... lizard skin ceramic coating inside and out on fire wall and entire engine bay. Inside pretty much the whole interior first layer 120 mil sound deadner from down4sound shoo. Com no affiliation second layer 320 mil sound deadner witch is actually 2 layers in itself another 120mil and 200mil closed cell foam all in all 440mil sound deadner plus the lizard skin ceramic coating on fire wall . Still need to do the transmission tunnel but have to fabricate the trans tunnel for manual transmission shifter and tcase shifter.
Might be a bad unit you got. I used the wire off of the back of the cluster at the tach
Can someone please help me with info. The LS is is in, took it for a test drive, but the 4h, 4L is not working. The vehicle runs good on 4L, which it should not. It should Tun good on Highway on 3h. It seems like something is back wards. And also, the. Enter lock switch does not come on when pressed. Is there some wire harness that needs to be connected from old stock transmission harness, or a sensor. It’s a 92 FJ80. With stick transmission, it ran great on 4H and 4 L was for climbing or low torque. What am I missing? I put a 5.3 with a 4l60e trans bolted yo the advance kit yo original stock transfer case.
There are a lot of variables here.
1) are you sure your locker harness is connected? Maybe the lights on the dash aren’t working. There are switches in the 3rd member that could be bad.
As for wiring. You only need the original trans harness with the extension to the Tcase.
Start watching from 5:58. You can see just about 100% of the harness to the transfer case is retained in the swap.
