Following/ Watching...
I've got the same problem, but have not started the process of investigating it. My problems started after a mechanic "fixed" / changed the breaker in my distributor. Its never been the same...
My thought process :
- Change the vacuum piping from the Carburetor. Just noticed it is fairly loose, dont think its doing anything. I will try to put a gauge on it.
- Check the distributor cap / electrodes and the "coil" inside.
- I also have some concerns on the fuel pump; might change it. Same mechanic put that doubt in my head, but I dont trust him. I will change the fuel filter first; that's a easy fix.
- Check / adjust spark plugs, valve spacing; then do a compression test.
If he just replaced the points, I'd 1st check the dwell, then go from there. Timing, idle mixture, etc. I wouldn't mess with stuff he didn't touch.
