Ok...not sure I understand?Hook a hose to the distributor vacuum advance port and suck on it. If you can suck air means its' diaphragm is bad.
so its better to keep RPM lower, say 570-590? its ok?That's good you got the idle down. The difference between the 60 and 40 could be a difference in timing adjustment .
I have vacuum advance. As per the FSM clipping, while the engine was at idle, i sucked on the tube connected to the vacuum advance. The engine RPM do not increase nor was I able to suck any air out of the vacum advance. So diaphragm is good, but vacuum advance is not working??
I found a replacement advancer for $30 in Japan. that's is easy replacementThe diaphragm could be good but that doesn't mean the mechanism is working.
