80 series rear axle with front axle Tundra brake mod (1 Viewer)
Anyone with the 13.5” 4runner rotors having issues with the rotor rubbing the inside of the caliper?
Anyone else with the 13.5” 4runner rotors having issues with the rotors rubbing the inside of the calipers?
Major parts cleaned and painted and I used the knuckle centering tool to set up the knuckles properly.
Knuckles went back together with new OEM fastners. Knuckle studs were upgraded, new cone washers, flat and wave washers, and nuts. Not knowing how many times these knuckles were dismantled and rebuilt, nor if parts were correctly reused, and that they've also seen a lot of use I decided to replace all with new OEM. Ordering parts through Partsouq eases the $$ pain.
View attachment 3424776View attachment 3424777View attachment 3424778View attachment 3424779View attachment 3424782
I'm so saving this for when I do this job....
I should have the Toyota part numbers saved I used for the caliper brackets (the stock bolts aren’t long enough)- think they were 100 series hub studs but will have to confirm.
They had a good shoulder and hood thread engagement.
I used bolts from McMaster Carr for mounting the caliper brackets and spindles to the knuckle. I didn't post the part number and could pull it out but OEM alternative would be better. I think I also used bolts from McMaster Carr for mounting the calipers to the caliper bracket. 80 series caliper bolt work here as well.
I have >1 million miles spread across a mini-truck, FJ40, FJ60s, and FZJ80, the OEM spindle nuts have always worked for me so I'll stay with them.
I should've mentioned I don't think they're better quality than OEM necessarily, but definitely just as good with the added convenience of being reusable and less likely for my sometimes shaky hands to have the socket slip off when torquing the nuts thanks to them being thicker.
Bitch’n write-up. Want to see how you work out the rear elocker. I have hopes to retro fit the H4 trans button space for the 80 series locker dial.
Just FYI, they have 2 versions of the tundra brakes early and late. Late style is the upgraded casting because of issues with pre-mature brake wear. Not at all sure if it will matter for your application.
I would think that the size/casting difference may effect the wheels you can run. I have the 13WL casting and run 17” wheels.
NookShneer, do you have a part no. for the 13WL casting brakes calipers?
  • Back
