great!!!!
I am in the same situation with my 40 as well....
This is great. it also gives me more insentive to pull the tub off and do the frame like you did.
Thanks for the push!
thanks! it's been rewarding so far. yeah, I'm on the lookout for a rear hatch and channels to convert my hardtop. most people in the south seem to run without tops, so i think that will be a longer term project after (if) I get this thing going.So you will be able to (have to?) run the liftgate/barn door style hardtop with that rear tub right? I like the way it's coming out! Proof you don't have to spend years and years and lots and lots of $$ to get these things looking good again!
Thanks! Maybe you and the others can help me decide whether to rattle can this thing flat khaki (Krylon Camo).......This will never be a show rig, but I don't want to ruin the value either.
I know it is late now but you made the right decision. I didnt have the money to do a showroom finish so I went the same route you did only OD green (link in my sig line).
There is no way you hurt the value. The truck will look darn good from 20', you get to enjoy driving the truck so that helps you not burn out, you can use it for what it was meant for (off-road) and not worry about scratching your gazillion $ paint job. This way you can start driving the truck and making it 100% mechanically sound and then, if you ever get a hankering, strip it back down and finish it for show.
I think you are doing a heck of a job. You mentioned getting burned out in a previous post. The best cure for that is getting to drive that bad boy. Keep up the great work.
Thanks man! It's good to hear from somebody who's been down this road. How's that Krylon Camo holding up? That's what I used to spray mine. Just curious, how well does it clean up?
Got the hydraulic system all together and starting on the wiring. Sent the Aisin carb off to Mark for a desmog rebuild and ordering some odds and ends. Hope to be on the road by May...
When it was first sprayed it had a rough texture and was hard to wash. I think I wet sanded it with some really fine paper, maybe 1600 and that helped a lot. If you use a courser paper, you will see the sanding marks. It is a fine line between getting it "washable" and leaving sanding marks.
Mine is holding up very well. The top is never on so the truck always stays in the garage(that is funny because my 100 series stays outside). I have not had to repaint anything. I have not had any remorse about doing it this way. When I go offroad, I don't worry at all about ruining my paint. I love it.
Hi All:
An impressive re-build project - you have made lots of progress in a short amount of time!
Regards,
Alan
