Nice weld!
Where did you source your 70 FF rear, and what is the length difference compared to the 55? Not familiar with 70 anything, but know the 60 axle housings are 70mm longer (wider) than 55’s.
Why 70 series TRE's?
They are the same as 60 but if buying a whole kit the 70 series drag link at the pitman arm end is different. Need that 70 end to use the 70 drag link.
Bj7x pitman arm has less droop if you find it hits the springs on compression. Also a mid 80s diahatsuu rocky has a flat pitman arm with the same spline counts
