- Joined
- Jan 31, 2013
- Threads
- 1
- Messages
- 301
- Thread starter
- #261
Engine mounted oil pressure gauge
Here is a small oil pressure gauge that will go on the engine. The 2F's oil pressure cooler banjo bolts at one time came stock with the oil pressure sender unit mounted on the bolt head. So, this is essentially taking out the sender and plugging in a small gauge instead. This 2F's OPSU came stock on the oil filter bracket; that sender will stay and continue to send to the dash. OPSU's were covered back starting at post #186:
https://forum.ih8mud.com/fj55-iron-...rivetrain-swap-84-fj60-drivetrain-10.html#186
I got some help from Jim C. on this solution. The topic started around post #196:
https://forum.ih8mud.com/fj55-iron-...rivetrain-swap-84-fj60-drivetrain-10.html#198
The gauge is McMaster Carr part number 9804T51:
http://www.mcmaster.com/#9804T51
Metric Gauges with BSPT Threads 1/8"-28, bottom connection, 0-60psi, dial size 1 9/16".
Jim C. originally referenced the 1-100psi. I hope I will not come to regret going for 0-60psi gauge instead.
In the pictures, the gauge is just finger tightened on the bolt. Thread sealant will be used during actual install.
