- Joined
- Sep 26, 2005
- Threads
- 38
- Messages
- 1,824
- Location
- Port Orchard, WA
- Website
- www.projektenterprises.com
I find that an additional 300lbs added to either end will help the ride (i used to have a skycrapper 4" before SOA)
Okay, I got a reply from Tom at Hell Creek. Here is the e-mail he sent me:
Not many people realize it, but the Nitro shocks actually contribute lift to the vehicle, since they are gas-charged (pressurized)
any updates on your spring/shackle issues?
extended shackles will make a difference in the angle also. you might try going to a stock size shackle.
Here's a couple more pics:
First one shows what i was talking about when stuffed. The picture doesn't show real well, but the right front tire is up on a berm. The shackle doesn't really push out. This was my first trip with the new suspension. I did the same test on a rock the second trip up (but forgot to take a picture ) and the shackle pushed out a little better. So, I do have hope that the springs will relax a bit more and give a little better articulation.
The second picture is just because. There is some beautiful scenery around here.
I'll update again once I get the new shocks on.
Oh, and no, that second picture is not the same as my avatar. It is actually another 5 or so miles up the road.
"Not many people realize it, but the Nitro shocks actually contribute lift to the vehicle, since they are gas-charged (pressurized).
Mark A.
With all of the positive feedback Hell Creek has received here on Mud, this is really disappointing.
Something in there manufacturing process must have changed, that's the only thing that makes sense.
Or it could be part of a small bad batch. These things happen to all the suspension companies eventually. There are scattered reports on most of the companies out there. NO ONE IS IMMUNE!
Is Alcan spring company the only one that stands behind there suspension products?
Hardly, but results may vary. Proffitts has not had good things to say about them, but I bought them anyways. Very happy...and...fwiw, the shackles on my 45 are straight up and down. Alcan designed and built the springs that way. Soooo, my droop is somewhat more limited than I would like.
It's not like Alcan's are that much more expensive...
True enough.
Thanks for keeping us posted on your spring upgrade, and post some pics when your done w/the rear.
Absolutely. I like your solution. Just not what you thought you were getting into when you started.
what was that saying, "...it makes you stronger"
Definitely! Props to you for your positive attitude.
manny
