Yeah, I could do that, but then the bezel police would be after me.Duh, flip your bezel and it should fix your problem..
Maybe take out a couple leafs??? See what that does.
Beyond the existing problem, could you post some feedback on these springs after running them for a little while?
This won't help you angles but it looks like you also need to straighten out your tierod.
If you could get those springs to settle to the correct shackle angle, i'm afraid it would have any lift to it. Contact the company, that isn't right at all. I will say it looks good sittin in the drive way. The right hieght for a 4" and it's level.
I installed a 2 1/2 Hell Creek lift about 3 weeks ago and posted pictures. I think you responded. My angles are almost vertical with a slight pitch outward. I am confident mine wil settle in ok. I don't think you can install them backward as there is a long end and a short end and you would have to move your axel several inches if you got them wrong.
Be careful with that angle. All it would take is a speed bump to invert those shackles, and you could bend your main leaf. Been their, done that.![]()
aw
So FF LC Freak, what do you think about those Rough Country 9000?? I didn't care for them at all........
FF LC Freak, I like your FJ40.
Gee, I wonder why?
Here is a pic of one of my front HC shackles, which has worse angles than the rear. I was a little nervous about them so I welded a 3/8 in coupler on the side of the shackle and made an adjustable anti-inversion screw.
Yours look way off. Send the pics to Tom Laher, I have found him to be very helpful.
tlaher@hellcreeksuspensions.com
it looks like u flipped your springs one side should measure 19'' and the other 22'' if you have these backwards that is exactly what it looks like...........tape it straight up and down from both eyelets to center pin.....![]()
I just installed the HC 4" suspension and 1 1/2 shackels and I have the same shackle angle is you. I was hoping that they would settle a llittle bit. Please post what you hear from Tom I was going to give it awhile before I called him.
