3D Print and CAD File Repository - 40 Series (3 Viewers)
More from my stash...someone already linked the Sniper mount. Canada-spec hardtop vents:
I also designed up the late-model dome light lens - it's still available from Toyota, but it was cheaper to print than buy...the base holds up, but the OEM lens fails with age:
Also added the STL version of the early dome light (I couldn't print SLDPRT), and some of the early-model apron badge clip doohickies.
  • badge-clips.stl
  • late-dome.stl
  • hardtop-rear-vent.stl
  • Early_Dome_Light_Cover_3D_File.stl
Oop, one more - small adapter plate to fit the Defender mirrors:
I did reuse the bottom hole, with a new hole up top as my doors were SA aftermarkets...one could make this thicker and use the factory holes if they wanted.
  • defender-mirror.stl
If anyone needs 3D printing done for their LandCruiser please feel free to contact me here on mud or via the link listed below! I print mostly in ASA a material that is 10x more UV resistant than ABS, I can print both in SLA or FDM. I can print FDM up to 450x450x440mm :cheers:
Hood spear made from two files so they fit on a small printer bed. The overall curve is a bit off but the mounting bolts pull it nicely into shape. Uses 3 standard 6mm bolts for mounting. The puzzle piece split is a bit tight as I designed line to line...
  • hood_spear_front.stl
  • hood_spear_rear.stl
Cookie Cutters:
Files:
I haven't tried these yet, But the outline only one should work with no problem. Detailed ones I'm not sure about.
Is the file still available? Link shows error. I would love to have this file!!
Cookie Cutters:
Files:
Hmm, seems to have been taken down. Uploading them here.
  • fj40_1.2mm_cookie.STL
  • fj40_0.8mm_cookie.stl
  • fj40_1.2mm_cookie_outline.STL
Call them. That seems high for shipping, but shipping is freaking nuts right now.
The postal service has been my cheapest option for shipping most small things.
Printed door handle grommet to eliminate movement of the handle. My assumption is that over the years the handle and the hole through the door gets worn from use.
Handle shaft OD 12.1 mm
Door hole ID 13.5 mm
Printed with PETG Filament
  • LC FJ40 Handle Grommet.stl
this past Autumn i dove deeper then deep into the whole plastic TIC TAC TOE straight pattern and earlier metal mesh on the 45" grill / screen that is mounted
inside the cab on the firewall between the inside duct and the exterior blower HVAC fan motor assy . .....
they seemed to change slight each other modle year or so , then the major shift from all metal to plastic occurred ,
it took a few Rodeos for me to get it spot on period correct right , as this was my first ever go at my own 3D reproduction part pjct. i was able to use my local TLCA chapter solid MUD buddies home-office style set up and i learned a hell of alot in the process too ...
i was like a teenager who froze at the shopping mall at Xmass time when the Local Rotary Club set up there multi 4x8 sheets of plywood full on life like better then MODLE RAIL ROADER Magazine HO trains live Display i would die for to go just forget about time and space for that special time
i felt the same feeling i forgot staring at the 3D printer doing its thing for the very first time too learning how to create my new and exciting form of Professional Mechanical Artwork .....
they snap right in and DO NOT warp and twist like all the ones i saw in person and online too..
- up to the inital dive deep R&D , i had no clue what Toyota called it , and thought perhaps it might not be a service part , maybe came with heater box or duct ?
thanks for letting me share :) :wrench: :wrench:
matt
- well here we go and there we are ..........
Part # 87294-60031
NET , AIR DUCT
FJ40
9/73-1984
( Deters Mice and Rodents from chewing wires and nesting in the HVAC system , that become shredded guts splatter you love to hate when the spring thaw occurs , and turns warm to OMG ! ........ 🤮
