2F serial number info... (1 Viewer)
1984
FJ40941008
2F671869
Don't know if it's the original engine. How can I know if it came with it?
For reference, the 2F serial number on my '84 FJ60 with a December 1983 build date is 2F 792002. I know it's the original engine because I bought the vehicle new and still own it.
From Post #373 on Page 19 of this thread, there's an April 1984 build date FJ60 with serial number 2F 822650. So that's 4 months for 30,648 2Fs, or about 7,662 per month. If yours was a September 1983 build date that would be 3 months earlier than mine, or a serial number about 3 X 7,662 = 22,986 lower than mine. 792002 - 22,986 = 769016. Doesn't really tell me one way or another. What is the build date of your FJ60?
Without looking through list what does 2f 883378 look like it came out of. It's in my 1980 fj40 ?
See Post #373 on Page 19 of this thread.
No production dates for the FJ60 that bracket your serial number, but they belong to @FJ40Jim and @Mace. In any case, from an '86 or '87 FJ60.
Ok found the list. And after cleaning I can see #s better. They are 2f 883396 so I'm guessing it is a 2f engine out of a 60 and dropped into my 1980 fj40 ? Does this sound right ?
Does this thread still want fj40 #s even though 2f engine was replaced ? I think my fj is a conglomeration of parts and years
Vin# on door post fj40317447
# on fire wall. Fj40307113
# on engine. 2f883396
Is it possible that the engine could have been shipped as a replacement ?
1978 RHD Aussie FJ-45
VIN# FJ45-207021
Eng# 2F 317349
Model# FJ45-RP-KQ
Color/Trim 416/LC11
From the Australian Spec Plate:
SD DATE 11/78
FJ40 production date 7/1978 I believe.
Vin # FJ40-282866
Engine # 2F 152840 - not sure if it is the original engine.
26zaKQyE1NSiOd2pIUbQqjSxnMuGiIKZlXikdGg-e1iLPMosRY8O_0Ko8V8WcAGI35rMEssiJq-cIFy5DBtNKSr-nxcJ5BroBZ0-8S4BmmxeUsA2TzJtMgP3TtwnLcDe4ZAEMvR4lsFgMPHFySedSOYu9H3XlpD7Wm2IgEpduLUiiOczodyplYEWut9LAjAj0F8U3kyzHX3BmCdldNtA7RuQP0W3h4HdnpECv0uQkge5tRsJZOE66E4oxkiG73DYq4tfh6E4St-69ukp-VkmGwOvFa1iFAOdGoLfRlcCTn-D51ZoI7SOJ8gliRYT8d-ADVN3C6r9pQvt5Re5ZyO9D6pKLXeDXME6w__yIwczZwnLH675IHzi3-oJejMgvCJiyfiC8wiOMxMhUtDwDy0xupHHFtVBhu0fkjMvbs1vWmpb6UZTB3QOFitKtAgVEPPB24d52OWfLNhpXzbQIGfqBX076mPB7JwtJTBaT6ql4_WjhwUHz4__9MR7xncP40zgcUkpKgIy4MiYztqMVpf6q75yz0-p5j7gzLg6_CkS5nOmvKidUU8TWhD2WBqsbspD3pHG5fAkLdWnQEqje-BvlLGKqPgAFY1wNogQ7ZDR7lNqorY6wggruw=w1352-h1014-no
If you have an original 2F in your 40 or 55, please post up your engine serial number, and the month/year of your truck build and the vin if you would. I am trying to complie 2F year data.
I will be posting this up in the 60 section as well.
Thank you for your help! :beer:
-Steve
Hi Fellow 2F Mud Registry Thread folks !
Here is a Unique unmolested Live specimen I have not run across before ?
- I have received several different Explanations & Reasons From Toyota Motor Corp. , Torance CA
- The Toyota USA Muesuem
- The land cruiser Heritage museum in salt lake city Utah ( Privately Owned )
- My trusted long term Tech contract @ SOR .....
- All provided basically a different reason , with some similar supporting facts
- To eliminate the possible PO grind OFF for smog reasons , I used me machinest stratghtb edge , and there was NO depression from
the Correct location 2F stamp to where the serial # ID should be .....its simply left blank ?
- it is a later / late 2F , oil cooler equipped .....
- NO Door Jamb A pillar data ID plate
- Engine bay one matches frame
- its currently in a 1/79 FJ55 W/ a split case and late aluminum type top shift housing
- please suggest any additional pics of info i can add confirm or verify yea or nea ?
factory replacement block. I have a 3fe like that...prolly .5mm over pistons and .25mm under on the mains and rods...at least, that's what I found in the 3FE...it has a toyotareman label on it.
  • Jdc1
