2F serial number info...
Found Frame number: FJ40219820
FJ40241763
77 FJ40
Engine..l. I looked at the panel next to the starter and it looks like at one time there was a decal there because the engine is not stamped. Decal in worn off except at couple corners.
Mike
Is there a spreadsheet-or another type of database that lists all these number replies?
Here is mine - 1976 FJ45, Engine Number 2F 073554 Frame Number - FJ45-113952
1977 FJ40 Freeborn Red
11/76
Vin: FJ40 237635
Eng # 2F 132687
Not sure if any of the previous owners posted this information up for you, but I figured I woud give it again to make sure!
1980 Toyota LC FJ-40
Color: 416 LP11
Mfg: Jan. 1980
Model: FJ40LV-KCJA
VIn: FJ40-317815
Engine: 2F 430316
Trans Axle: H42 K052
Plant: A11
Block that I got for my 2FE is 869263 - from an unknown donor vehicle. Looks to be a late '85 FJ60 block, I suppose.
Hey there. I was taking a look at the spreadsheet on Poet #374 and noticed that you have me listed twice. The bottom one is probably because I originally gave you incomplete data, so you should remove that one.
I also noticed that you have my build date as August 1983. My correct build date is September 1983.
