2F serial number info... (1 Viewer)
Found Frame number: FJ40219820
Just bought another FJ40 here in Ecuador. The chassis number indicates 11/79 build. But I can't find a charge that goes beyond 1978 for the engine number.
FJ40313234
2F411629
FJ40241763
77 FJ40
Engine..l. I looked at the panel next to the starter and it looks like at one time there was a decal there because the engine is not stamped. Decal in worn off except at couple corners.
Mike
Is there a spreadsheet-or another type of database that lists all these number replies?
Here's a few more
Sep-79
FJ40312337
2F 399068
White
Dec-79
FJ40316323
2F 422741
White
Nov-76
FJ40235633
2F 126088
Dune Beige
Nov-79
FJ40281806
2F 408455
Here is mine - 1976 FJ45, Engine Number 2F 073554 Frame Number - FJ45-113952
Not 100% sure that the engine is original to the rig.
76 FJ40
Prod March 76
Engine# 2F 082263
1977 FJ40 Freeborn Red
11/76
Vin: FJ40 237635
Eng # 2F 132687
1976 FJ40
Vin # 221895
Model # FJ40OLV-KCJA
Engine # 2F083644
FRAME # FJ40- 221895
Color # 621 LE11
Trans Axel # H42-K0820-12
Plant # A11
I'm not sure why I've never posted mine here.
Build date: 05/1976
VIN: FJ40 225361
Engine: 2F 93854
Not sure if any of the previous owners posted this information up for you, but I figured I woud give it again to make sure!
1980 Toyota LC FJ-40
Color: 416 LP11
Mfg: Jan. 1980
Model: FJ40LV-KCJA
VIn: FJ40-317815
Engine: 2F 430316
Trans Axle: H42 K052
Plant: A11
Block that I got for my 2FE is 869263 - from an unknown donor vehicle. Looks to be a late '85 FJ60 block, I suppose.
Hey there. I was taking a look at the spreadsheet on Poet #374 and noticed that you have me listed twice. The bottom one is probably because I originally gave you incomplete data, so you should remove that one.
I also noticed that you have my build date as August 1983. My correct build date is September 1983.
  • Jdc1
