Hello all,
Currently in Moab and having a new issue I've never really heard discussed before. It is similar to the AC fan issue as discussed here, but in my case, my motor is definitely getting warm. The temp gauge has made it a solid 3-4 ticks higher than normal and my AC goes away as well.
I'm with a four vehicle group, including my 100, a Taco, a Wrangler, and a Gladiator. Now, it's been hot. Really hot. Air temps between 95 and 108, and the ground is hot enough to burn. While moving, the 100 seems to cool itself down fine, but when stopped, the temp gauge starts climbing. I've been opening the hood whenever we stop to spot the various vehicles through tight spots, and that seems to mostly solved the problem, but it's far from ideal. Also, holding the revs up around 1200-1500 gets the engine fan moving enough air to drop the temps as well.
Neither of these is an ideal solution - has anyone run into this and solved it? I'm thinking adding LandCruiserPhil's condenser fan would probably help, but anything else?
The radiator is in good shape externally, the coolant is full, and it's all nice and clean. Water pump and thermostat were done with timing belt around 110k miles, and I haven't had a single issue with the cooling system before this, or when driving around at speed in ridiculous temps. Just when idling over ridiculously hot ground.
Also I've run into the fuel boiling issue as well - that's been fun. Hasn't prevented the 100 from running but isn't great to have constant fuel vapors/venting from fuel tank.
