Builds 2001 LC HZJ78 AK -RESTORATION- For Overland (4 Viewers)
Portable grinder
Wiring harness done ✅ unfortunately we had to pull down the long ranger 180l tanks believe it or not he sending unit broke inside and the metal arm was loose inside 🤦🏻‍♂️
We had to swap the metals sticks on the sending unit because it was indicating upsides down anyway problem resolved this was beneficial since I had space to play with the wire
Now we will finish the bracket for the cabinets before putting back in place
I also installed the CB and did the wiring for the heating seats using a old plug for the power window that I don’t have
Moving the Hood cable 2 holes I was able to reused the space to mount the bracket
And small thing I found a perfect match for the road
Tommy, I have the same bottle... 😂
Is that hydroflask hold sold somewhere or did you make it?
I had the chance to hook up temporarily the front fogs on a independent switch for day drive and finished the antenna set up
I was not happy with the bumper taillight light they were clear and sprayed them red along with a 2 inch orange flasher
I think I will only use the switch pro for interior electrical outlets … decision decisions
This could be a very interesting option! I will test the SD this summer and see how loud it feels 😱😅
What about heat insulation? You probably need it more than me. 😀
Or I guess the 5 KW Espar will keep the place toasty. We have one in a Sprinter van and in 12 min brought it from 18F to 52F.
I have purchase some sheep insulation for the quarter panel but that's for in a while until I finish up the real estate cabinet and for now it's a puzzel the 5KW it also a challenge to mount too... Honestly I am still thinking about the fuel line T for the espar and wabasto cook top for now should have more info during the week-end as we are planning to fit water tank and line too
Nothing major today I relocated the espar fuel pump closer to the other side now need to get a T to make a junction between the fuel tank and wabasto cooker. Also thinking about an actual hermétic way to get fuel out don’t like the plastic line provided
Made some progress on the cabinets the LHS is done and we advanced the RHD we will need to complete the welding once position perfectly
After 2 week of testing fitting I have found a way to have a Stand pipe directly inside the tank (metallic) hermetically sealed while testing M6 female and 1/4 female barb I thinks this is the proper way to have diesel ⛽️ to the cook top wabasto and espar
M6 Stand pipe with M6 thread
Barb with 1/4 female threads
Teflon insulation with M6 nylon nut to lock everything
T split to hook both fuel pump later on in the process
