200 Series Tire and Wheel Size Database (32 Viewers)
You running UCA's?
I dont think @Tex68w is on here much anymore. Ive got the Nomad Sahara in this same offset with a little smaller tire but could easily run this same size. I was able to get mine aligned without UCA's, but it was recommended to upgrade when needed.
Just put a set of Cooper Discoverer ATP II in 285/70/17 (Rock Warriors) on my 2013 LX570.
@gaijin - could I trouble you for the RCTIP for these tires? Thank you kindly in advance!
LX570 stock - Method 18x8.5 +40mm offset
275/65R18
Will this setup rub? I am not sure how this offset affect it. oem is +55mm 21"x8.5
Will it rub with AHC in low? I don't drive in low just wondering as it takes a few seconds the raise the body.
275/65R18
i have this exact wheel and tire setup. it rubs on a LC
Quick question that I was having trouble confirming. Will the Wildpeak 285/65/R18 fit on a stock 2021 Landcruiser Heritage or would I either need to drop down to the 275/65/R18 or do some slight mods to avoid rubbing?
I did tons of research, and was going to do 275/70 or 285/70.
I chickened out and went to a 275/65 General Grabber ATX. I get rubbing on full lock and in reverse uphill.
In general 285/65r18 and 275/70r18 will fit with minimal to no rubbing depending on brand as size isn’t uniform. 275/65r18 fits easily. I don’t know about Wildpeaks specifically.
285/65/18 ko2s here with +25 offset wheels, no rubbing. Hoping to go with 285/70/18 next time around with none to minimal rubbing and no modifications to bumper/liners/etc.
Throwing this out there for a hopefully quick reply...does ANYONE know if 285/65r18 will fit in the spare tire well of a 13 LX570? I need to make a switch and tire shop has them but before I commit to buying 5, I wanna know if it fits. They have my car and dont want to say yes it fits or no it doesnt....
It will fit.
Visual comparison of KO2s in LT285/75r17 (37psi) and 35x12.5x17 (37psi). It is important to remember that the side by side photos don’t accurately reflect an “on vehicle” comparison. The hub surface is not at the same vertical or horizontal plane.
Rock warriors, no spacers. No KDSS or front sway bar.
