Stock height?Man that looks soo good. I mean bad.
Looks great. I am looking at exactly the same set up. Dobinsons and Vector 5 (gun mental though). How does it ride?All my worrying was for not, the 200 came out looking absolutely fantastic in my opinion after adding the Dobinson IMS 2.0-2.5" Suspension Lift, Icon Vector 5's, & 285/75/r17 Toyo AT3s
You running UCA's?A few adjustments still need to be made but here’s a quick parking lot snap shot post wheel/tire install. OME 2” lift with 285/75/17 KO2’s on Nomad Arvo 502’s.
I dont think @Tex68w is on here much anymore. Ive got the Nomad Sahara in this same offset with a little smaller tire but could easily run this same size. I was able to get mine aligned without UCA's, but it was recommended to upgrade when needed.You running UCA's?
You running UCA's?
i have this exact wheel and tire setup. it rubs on a LCLX570 stock - Method 18x8.5 +40mm offset
275/65R18
Will this setup rub? I am not sure how this offset affect it. oem is +55mm 21"x8.5
Will it rub with AHC in low? I don't drive in low just wondering as it takes a few seconds the raise the body.
Dobinson’s suspension. I think it’s 2-2.5” lift? It has been so long now I forget.great suspension setup. Any details?
Thanks!Dobinson’s suspension. I think it’s 2-2.5” lift? It has been so long now I forget.
Tire size? Lifted?Thank you, they are the 116Q SL. I think they are a very nice ride and the road noise I very minimal. I took my dad for a ride to get his thoughts. He is very noise sensitvie. He also agreed that the ride quality was great and noise was very minimal and not noticeable if having a conversation or listening to the radio.View attachment 2336399
I did tons of research, and was going to do 275/70 or 285/70.Quick question that I was having trouble confirming. Will the Wildpeak 285/65/R18 fit on a stock 2021 Landcruiser Heritage or would I either need to drop down to the 275/65/R18 or do some slight mods to avoid rubbing?
In general 285/65r18 and 275/70r18 will fit with minimal to no rubbing depending on brand as size isn’t uniform. 275/65r18 fits easily. I don’t know about Wildpeaks specifically.Quick question that I was having trouble confirming. Will the Wildpeak 285/65/R18 fit on a stock 2021 Landcruiser Heritage or would I either need to drop down to the 275/65/R18 or do some slight mods to avoid rubbing?
Yup same tires on my OEM wheels, no issues.275/65r18 fits easily
It will fit.Throwing this out there for a hopefully quick reply...does ANYONE know if 285/65r18 will fit in the spare tire well of a 13 LX570? I need to make a switch and tire shop has them but before I commit to buying 5, I wanna know if it fits. They have my car and dont want to say yes it fits or no it doesnt....
