Yikes...good to know. Good thing I was already planning to do it myself then.
Man, some shops. It takes some specialized equipment but $1400.
I would pull the head, pop all the springs and valve seals so all the valves are loose(don't let them fall out), then take it to a head shop. Then you can set it on a table and they can tell you what they will probably want and need to do. They can't quote correctly until they break it down that far anyway. That's why they quote so high to begin with. You always want to keep track of valve spring locations. Get some calipers and measure the spring free length. My $.03
Its ok....havent had time to do anything other than order a head gasket set......
Does the F engine repair manual cover head gasket replacement? or is there any other ref other than
the fsm I don't have?
Just got the results of a compression test myself last night, cyl. #4 is dead (70psi)...feel your pain, man. Shop did a leakdown test and suspects it's an exhaust valve...quoted $1200-1400 for a cylinder head rebuild, so your shop sounds like it's giving you a similar quote. Hope things work out for you...
