1HDT TPS removal
texas
Hello all,
How on earth do i remove the TPS from the injection pump? I cannot remove the screw closest to the engine. Is there a special tool?
Ive developed shifting issues after an injection pump rebuild (very late shifts, extremely sluggish) and i suspect the TPS was reinstalled incorrectly or has gone bad.
I believe the TPS is only on the 1-HDT if the truck is also equipped with an electronic controlled A442 transmission.
I used a small bit ratchet to get that one off. Enough space to push down on bit as you loosen. $15 or so for it.
Check my signature for my HDJ80 work - I posted a video on how to adjust the TPS on this engine.
