- Thread starter
- #101
Didn't get nearly as much done today as i had planned!
It was a long day and ended up spending most of it chasing parts and chemicals around town. My friend who has been helping me was delayed until about 1:00pm, so i figured i will run to NAPA and get some parts washer fluid. Went up, couldn't beleive the price ($110/5gallon) but really was in a pinch to clean some parts; so i bought it. Took the guy at NAPA 15 minutes to realize and tell me the guy in the back couldn't find it.
Said i could buy there and pick the same thing up at the store across town, so i said sure and off i went with receipt. Ran in, flashed the reciet, ran out with the parts washer cleaner and headed home. Got home and the bucket clearly states "not for use in parts washers"
I will be returning it tomorrow.
so off i headed to lowes to pick up some mineral spirits as a substitute. worked great and started putting the gears on and realized i didn't have a 10 MM allen head socket that i could torque with my torque wrench.
So back to the store for allen head sockets and the get back to wrenching.
Seals in, surface prepped, FIPG ready to go, realize that i got accidentally skipped on two gaskets from my shipment. one of the oil cooler gaskets and the oil pump cover gasket.
So i can't install the oil pump cover.
BUt at the same time i realize i haven't purchased replacement torx for the cover anyways! So i need to do that.
Oh well, call it!
Anyone want to remind me what size torx bolt to get for the oil pump cover so i don't have to search?
Also on a serious note, the FSM does not show which way to orient the oil pump gear (i guess you would call it the orbital gear that moves around the center stationary gear)? I ASSumed that since there is a mark on the underside of the oil pump drive gear that the orbital gear would also orient the arrow on the lower side?
I will be returning it tomorrow.so off i headed to lowes to pick up some mineral spirits as a substitute. worked great and started putting the gears on and realized i didn't have a 10 MM allen head socket that i could torque with my torque wrench.
BUt at the same time i realize i haven't purchased replacement torx for the cover anyways! So i need to do that. Oh well, call it!
