1FZFE 5.2L Turbo Build (4 Viewers)
There's a turbo in there. I have proof:
I can see the turbo, but I don't see a transmission. Is it already gone? :rofl:
  • Haha
Reactions: JMM
Did the transmission survive the dyno?
Process delayed (... understatement of the year). Should be on the dyno soon. Last check at the shop, they were welding custom exhaust segments and hooking up the transmission cooler lines. Minimal fab remains before we're tuning...
  • Brian Crower Toyota 1FZFE Stroker Kit @ 5.2L
  • 108mm Stroke Billet Crank
  • Billet Sportsman Rods
  • Custom JE 101mm 8.5:1 Compression Pistons
  • ARP 93-98 Supra/01-05 IS300 2JZGE Head Stud Kit
  • Engine rebuild kit with new gaskets, bearings, timing chains/guides, etc..
  • Machining: bore/hone, cylinder head rebuild, etc..
  • Swapped internals to JE Pistons, BC Crank, and new H-beam rods
  • Custom machined crank, machined pistons, balanced assembly, and reassembled motor
  • Turbo = Borg Warner EFR B2 7670 .92AR VTG WQ
  • EFR Install Kit
  • T4 Inlet Gasket
  • FPRO35-060-03 PTP Turbo Blanket Large EFR 7670+
  • Injector Dynamics ID1050X Injectors 11mm (Blue)
  • Denso Lower Cushions (Set of 6)
  • Turbo Intercooler
  • Link G4X Fury ECU installed as Piggy-Back to EOM ECU
  • Full Performance Exhaust
  • Ceramic Coat Downpipe
  • Custom tuned ECU on Dyno
  • Fluidyne 2-PASS OIL/TRANS COOLER
  • Brown and Miller Plumbing for trans cooler and turbo oil feed/return
  • CSF Toyota Land Cruiser 4.5L Heavy Duty 3 Row All Metal Radiator
  • Lexus LX 450 / 8/92+ Toyota Landcruiser 80 Series Front Slotted 4000 Series Rotors
  • Lexus LX 450 / 8/92+ Toyota Landcruiser 80 Series Rear Slotted 4000 Series Rotors
  • Hawk LTS Truck/SUV Pads (Premium) FRONT
  • Hawk LTS Truck/SUV Pads (Premium) REAR
  • ARB / OME Nitrocharger Sport Shock Landcruiser FRONT
  • ARB / OME Nitrocharger Sport Shock Landcruiser REAR
  • Motul RBF 600 Brake Fluid
  • Brake labor to install pads & rotors and bleed brakes
  • Suspension labor to install shocks
  • New ARB Bull Bar Non Winch Mount Bumper (Black)
  • Clean and undercoat frame, axles & links with military spec black Cosmoline
  • Misc: Gasket Oil Cooler, Gasket Oil Pump, Spring, Valve, Thermostat, Water Pump, Injector O-ring, MAXLIFE-D Valvoline, Maxlife ATF
Looks great ! And the brake line doubles as a limiting strap 🤔🤣
If you’re going there, the diff breather his pull off as well 😜
I wish the list was that short...
No offense intended, I have enjoyed following your thread, thanks for posting.
Anxiously waiting for that beast to roar !!
Obviously excited to following along and live vicariously thru you :) thanks for bringing us along.
Can you share intercooler location + pipe routing when you’re done?
Intercooler fits behind grill and low in front of radiator; there's a surprising amount of dead space right in there...
Zoom in on last picture posted above...
You can see the warm side stainless "L" around the valve cover, then drop down the driver's side of the fan shroud; goes forward by frame rail.
Cold side return follows passenger frame rail straight back, then pops up behind/near the turbo. You can see where it's poking out (loose) for flex connection across to the intake manifold.
Downpipe near factory exhaust route, just bigger diameter with Cerakote and a woven stainless flex section.
(All that was rough-fitted and fab'd before engine disassembly.)
Rejoice, people of mud, for the beast is finally alive! Started right up with no issues on factory ECU, and sounds like a regular Cruiser at idle. Piggyback tune, bigger injectors, and full boost coming soon...
  • EFR Install Kit
  • T4 Inlet Gasket
  • Turbo Intercooler
Summary:
We definitely need some pictures and video now!
On what is likely a giant sidetrack, I saw a thing on one of these motor trend type channels about the nissan CD009 transmission (6 speed manual) from the 05-06 350Z, and its apparently popular for its cheap price and mod-ability, although its a 2WD trans and is used for LS swap stuff kit. It likely would be quite involved with a transfer case in your situation, but its an interesting trans swap option for some projects for those who like to read.
The ZF 6 speed is interesting too, no clue if either of these things would ever fit. But people sell adapters, and people sometimes make their own adapters..
  • Like
Reactions: JMM
