This is what happens when you allow scope creep on an engine oil leak in your 80...
Finally nearing completion on the subject build after a really looooong wait. Turns out there's a good reason we don't see many of these outside Dubai's sand drags; a lot of experimentation and custom machining work has been required (difficulty rating = $$$/$$$). Ended up with 108mm stroke on billet crank, 101mm bore, fresh H-beam rods, modified 8.53:1 race pistons, and Supra head studs. Will run a 61lb/min turbo via custom piping and intercooler. Intentionally detuning to avoid over-stressing internals and/or destroying the transmission. Should have more updates in a few weeks, after dyno time.
