Hi Guys,
I have an 80 Series that w/A343F Tranny that was just "re-built" by my transmission guy. And I'm having the same problem that I had in my 94 ( A442F). Coincidentally they both are having the same issue. When put into drive and trying to accelerate, the rpms raise and the FJ doesn't want to move. It's slipping very badly and eventually it slowly goes and rpms match the speed, then once up to speed it's fine. Also when placed in Park the FJ moves like it's in neutral, the E-brake must be applied so it doesn't roll. Also, if I put the FJ in low range, it works just fine, no issues in park or starting off/shifting..
My Transmission guy says my transfer case needs to be replaced. I've had this same issue on the 442 and 343. I've already paid him to rebuild the tranny on the 343 and now he wants to re-do the transfer case...? Fluids are topped off and fresh considering the rebuild was 500 miles ago..
Any thoughts would help..
95 FJ
A343F
158k on motor and body.
500 miles on tranny "re-build"
Triple locked
6" Slee lift
37" nittos (no it doesn't rub)
stock gears.
95 FJ
A343F
Triple locked
6" Slee lift
stock gears.
