Since you are pulling the radiator you have to disconnect the tranny lines at the bottom of it, could replace those also now
Why not just use an OBDII reader instead of a dedicated coolant temp sensor? Also, I'd recommend a complete set of constant tension breeze clamps to replace the standard hose clamps. Pretty sure @NLXTACY sells a complete set. Tightening the breeze clamps in tight spaces is so much easier. And if you're getting a new OEM radiator, it comes with a cap (at least mine did).
Do you have a PN on the trans lines?
Great idea! I’ll look for the Breeze clamps from NLXTACY.
I thought '93 trucks had OBD I?
I'm getting a Ron Davis radiator. It comes with a radiator cap, but I didn't know if I should swap it for OEM Toyota.
Did I miss it or did you address the infamous PHH?? Check the condition of the heater valve too at the firewall center. With the rad out might as well do belts and the 2 pulleys to get that super quiet sewing machine idlefor the Koso, I used a Glowshift sleeve on the upper rad hose that has worked great for 40000 miles now. I rebuilt my black hub fan clutch like @baldilocks but put 10000k and saw a definite improvement in cooling during summer. Whatever you do with your black hub, don’t scrap it.
The trans cooler hose that you might consider replacing with an oem part is the one that transitions from the cooler line to the radiator passenger side. It has a formed shape that helps keep it away from the the fan and crank pulleys. The rest can be replaced with gates 1/2” tranny cooler hose purchased by the foot at most any parts house.
Yes, 1993 is obd1. That’s why I suggested a Koso.
This is a good time to go all the way and replace every single hose under the hood and while you have the PS plumbing removed, replacing the driver side motor mount is much easier. Motor mounts are rubber too. Mine were hard and cracked. Replaced my tranny mount too but Toyota calls it an Engine Isolater also.
Did I miss it or did you address the infamous PHH?? Check the condition of the heater valve too at the firewall center. With the rad out might as well do belts and the 2 pulleys to get that super quiet sewing machine idle.
For the Koso, I used a Glowshift sleeve on the upper rad hose that has worked great for 40000 miles now. I rebuilt my black hub fan clutch like @baldilocks but put 10000k and saw a definite improvement in cooling during summer. Whatever you do with your black hub, don’t scrap it.
I saw an HPS silicone hose set on Amazon. The feedback earlier in this thread was to stick with OEM rubber because the aftermarket silicone kits tend to leak.
How has your experience been with the kit? Any leaks?
Only a couple of thoughts, if you like to keep the stock dashboard then do this:
93-97 Coolant Temperature Gauge Modification
I use an all electric cooling fan, there are mixed options about this but, at least there is some agreement that an electric fan will give you better AC.
Sudden water loss can be picked up instantly by this:
Cartek Coolant Level Alarm | Demon Tweeks.
Would this be the right time to fit an external transmission cooler?
Regards
Dave
Thanks!
I'm not too worried about a catastrophic and instantaneous water loss. I've never seen or heard of that happening. Plus, if the coolant system failed catastrophically and dumped 3 gallons of water out of the truck, don't you think you would notice an event like that (without a warning gauge)?
The FZJ80 already has two transmission heat exchangers. A conventional liquid-to-air cooler on the DS front, and a liquid-to-liquid heat exchanger in the radiator. Are you saying you'd like to add/upgrade the cooler?
Water loss can occur overnight for example, come out start up and you get an instant warning. A free a sudden loss dumping water over the exhaust and the resulting steam would be a good sign of a problem, what about a steady loss, unless you are an avid gauge watcher you may not notice until it is too late?
Transmission contamination by an internal leak ftom the rad can be costly, given how keen you are to get it done right, a seperate liquid to air cooler was just a thought.
Regards
Dave
