1993 FZJ80 Cooling System Overhaul
Hope this helps!
Also, about this comment from @murf about a S/C engine with RD rad--
"Thats what I did. the reason is that the original fan is replaced with the TRD supplied "ringed-fan". The 3FE fan was tested by a couple guys in Copper State a few years back and found with the much thicker and wider blades, it pulled substantially more air than the ringed fan. I dont know if anyone ever compared the 1ZFE fan with the 3FE?"
Might there be an advantage to replacing the current FZ fan with an FE fan, if still available? Will it fit the FZ blue hub fan clutch--or (being heavier) alter its performance or affect the water pump? (@NLXTACY ? @landtank ?)
Here is mine (RD) i have installed about a yr ago. Zero complains here.
Suitable for framing!
This is in a '91 though, right?
Cant seem to find any more trans oil coolers, does anyone know of a minimal cutting or drilling or even direct fit aftermarket for a 1993 FZJ80?
Great thread, im down the Ron Davis Rabbit hole now.
Those with the RD still happy? Anything you would do differently? How about some Wit's @NLXTACY fittings?
This is 80 series porn at its best. Good lord its a work of art, i must have one.
Anodize it, like he did. :)
I have never heard or read reports of the 80 series trans running hot. All info I have read indicates quite the opposite and to see my own trans temp gauge above 150-160F is rare and it usually runs 140F.
Any auto trans can get hot which is why they all have a temp warning light circuit.
Running the trans fluid through the engine cooling system isn’t just for quicker trans fluid warm up. This fluid routing helps to adjust the fluid temp to and temperature that is more of a known constant and which the fluid to air cooler is capable of then adjusting to what the engineers wanted. Trans fluid to water cooling is much more rapid and effective than fluid to air.
I don’t really believe that the air to fluid cooler could do the job as a stand alone unit when the trans is being taxed extremely, due to the fact that the torque converter is capable of heating trans fluid to much higher temps than the engine normally runs.
In summation: I believe that routing the trans fluid through the radiator plays an important roll in controlling trans fluid temps at both extremes of the operating range.
@Will Van - it’s not that silicone hoses leak in the traditional sense, it’s that water will actually penetrate the wall of a silicone hose and water (not glycol) content in the system will be reduced. For this reason, fleet owners/operators do not use silicone hoses.
For us, this is probably not a significant issue, I just can’t think of or remember one reason to pay the premium to have silicon hoses.
Just cross-posting from @iansplatinum's thread, on the transmission thought I posted there. How are you assessing the transmission temperatures?
Regrets to @Will Van for piggybacking on his thread ;)
My post that you quoted was referring to a properly operating 80 series transmission. My trans oil temp sensor is in the oil pan. This provides a good indication of core temp.
