- Thread starter
- #241
I will have to get my AC working fairly soon as well. We are close to starting our 3 week spring season, then all bets are off
Euro spec Kia, dumb@ss.Glad I was able to help! That is one sweet jeep you've got!![]()
Dammit, now I have to get another name tag just for you John ...Euro spec Kia, dumb@ss.
Your schematic shows the majority of items to be 12v switched. So you have the power feeding the 24-12v big convertor as switched power. For my setup, I'd like a number of things to be constant...the CB radio, a dual USB plug, etc. So would I need to get a second large convertor? One for switched and one for constant?
Also, the relay you have to use for stereo illumination, would that feed be good to use across stereo and auxiliary gauges?
Last question! I was hoping to use Contura LED switches, but I don't think the bulbs are rated for 12V. Any idea how to handle that? Most of the switches have a dependent and independent light. So the independent light could be tied into the relay for illumination noted above. But the dependent light would have 24V going across it if it were controlling a 24V device, which I don't think would work.
I'm OK with a little bit of electrical work, but in this case the 24V system puts things above my pay grade!
Thanks in advance for any insight or assistance!
Glad to see you are keepin' this thread tech......Since I have owned the truck, the RH or passenger side rear view mirror has been bad.... cracked housing causing vibrations and flat glass making view narrow.
For those of us with a rural education, are the objects in the mirror, larger, smaller, or just right? : )JDM mirrors are convex on both sides. I've grown to like that a lot.
I have limited experience in such exotics....JDM mirrors are convex on both sides. I've grown to like that a lot.
It is convex. Based upon Dan's comment, I do not know if it is proper EU / LHD spec or JDM spec. If Dan would share the PN for the JDM Left Hand mirror with convex glass and I might get one of those tooGlad to see you are keepin' this thread tech......
Did you get the LHD version of pass side mirror with convex glass?
My recent orders were for early OEM (small) to replace the '85 units and later OEM (large, aka "Dumbo") mirrors for a possible upgrade. Not sure what market(s) for which these were intended.It is convex. Based upon Dan's comment, I do not know if it is proper EU / LHD spec or JDM spec. If Dan would share the PN for the JDM Left Hand mirror with convex glass and I might get one of those too
