Builds 1978 US Market FJ40 Factory Restoration (12 Viewers)
Hazard switch. Normal course of action might be to find another or buy one. However a small flat head screwdriver to carefully pry open the tabs and wiring harness revealed what I'd hoped to be an easy fix:
Quite a bit of dirt and grime fell out - and comparing the contacts....I saw exactly why GO and GR were not passing 12V. (Which if you are rebuilding one, I made this diagram):
If you have the switch in your hand, removed from the truck and look in the end of the plug:
1. With the switch pushed in (OFF) pins 2 and 3 will have continuity with each other and none else. (this allows current to flow through your normal turn signals)
2. With the switch pulled out (ON) pins 4, 5 and 6 will have continuity with each other and pins 2 and 3 are interrupted with a new 1 to 2 connection, overriding your turn signal switch and sends voltage to each side turn signal.)
My pins 2 and 3 failed. You an see the build up on both sides.
Q-tip and Brasso:
Cleaned with rubbing alcohol:
Same thing for the other side. Then, lubricated with dielectric grease (Super Lube is dielectric)
Reassembled:
Test:
Thanks @Green Bean ! Very satisfying for sure. Now, onto the headlight switch.
Problem: 1st pull on the headlight switch, only headlights come on. 2nd pull, All lights. Seems the headlights and parking light wires are swapped somewhere.
With the defrost tube, it is rather annoying digging around in there working on the light switch. Grrrrr. But....that is next on the list.
2. With the switch pulled out (ON) pins 4, 5 and 6 will have continuity with each other and none else. (this interrupts pins 2 and 3, overriding your turn signal switch and sends voltage to each side turn signal.)
Q-tip and Brasso:
Reassembled:
Test:
Just one small addition to what you stated in case someone is reading this later and troubleshooting. In the on position, pins 1 and 2 are connected as well. This is what sends the power to the flasher and what was causing your issue (GO and GW open and not making a connection). Nice fix!
Looking for links/ideas/solutions on a muffler that looks like the original round cylinder. I'm having a hard time finding something that looks OEM.
Will continue to google around to see what I can find.
@fj40ingkc - didn’t you find something close to OEM for one of your 40s?
Yes I found an OEM one, last one that seems to be available, and then I bought a few mufflers trying to match the size and dimenstions. One of them seems to be just about correct and can be welded to tubing designed to match OEM route. It’s for the muffler that goes in rear behind rear axle.
Dallas, this deal should help you out on shipping if you track down a muffler part number:
25% off orders between September 25-29, and free shipping on orders over $75. They emailed me that link yesterday.
I've ordered quite a bit from Serra Toyota in the past.
Andrew
I’ve had it a year now, it looks correct for the size and shape. Would need to bend the other tubes to match/buy fittings that are correct to bolt components together. I’m debating going stainless will update as I move forward :)
