DanS HJ-45
I enjoy this thread so much its not even funny. I have a question about all your panel replacement and spot welding. Now i have never done any type of work like what your doing ... ever... so this question is for my education. You are using a sander/grinder to flatten down all your spot welds to make it all smooth. What about the backside of all your spot welds? I know most ... if not all of them won't be seen but are you suppost to grind those as well and take the same steps as you do on an outside panel... as far as making them all real smooth, then prep work, primer, sanding, painting, buffing...stuff like that. Is the backside of all your panels suppost to be the same quality as the side that is seen by all?
I won't speak for Kevin, but I work to smooth the backside of all welds if I can. I figure that the less places for dirt and water to accumulate the better. The weld bead can certainly hold dirt and water if you aren't careful, and then of course you get to repair the rust again someday...
Dan
