- Thread starter
- #41
These of the type of body mounts he used . The one in the picture is thick. Then there’s two that are basically half that size that are on some of them. Just noticed he put the one on in the very back towards the back bumper on wrong. It’s two pieces and he’s got the one below the tub mount but then another one above it instead of both below it where it supposed to be. That made me curious as to being level. When I put a level on the back it shows that the back is lower than the front. That would explain why I would have a crack in between the cowl and the front fender up on top. I did not install these so I don’t know which ones go where. Thinking about buying another set so I can make sure the right ones go on the right place.Can you look and see if you have the short and tall body mounts in the correct locations? I mixed mine up and had a similar issue.
