Builds 1969 FJ40 named Mavis
City Racer FTW!
I may be wrong, but I'm thinking that the floor switch is still available OEM.
I very well may be mistaken though.
Never mind, I can't find it on his website anywhere.
A quick Google search gives me 84140-59620 as the part number.
ALL these links are the counterfeit ones
i know because i got burned over the summer :confused:
they all have a shinny gold bumper part cap ,
all have 3 screws too , TOYOTA or TR company NEVER came with 3 screws :mad:
the TR in the circle is really a IR
retro tru-counterfiets
LOOK CLOSLEY the
IR in the middle ...........
i know this seller EKooke
this IS a LEGIT REAL Tokairika GENUINE TOYOTA Floor Dimmer , :)
he IS a honest seller too , from my experience ........... 🍀
I used this Fuse Box & Cover from City Racer. The dimmer switch I drilled a little hole in the bottom and sprayed it with contact cleaner and worked it back and forth when it quite working.
Other than rusting solid, I've never seen a foot dimmer fail in any of my vintage vehicles. Is it advisable to get one just in case?
Mine would not switch, after spraying it with contact cleaner it works fine. Not worth rat holing that part to me.
The speedmarker detector is inline with speedo cable-has 2 wires at approx 10" away from speedo cable end (at TC) which then go to the relay (firewall) then to the VSV (vacuum switch valve)-drivers fender. Not part of TC but emissions/distributor retard function.
