Build 1969 FJ40 named Mavis
The speedmarker detector is inline with speedo cable-has 2 wires at approx 10" away from speedo cable end at TC which then go to the relay then to the VSV (vacuum switch valve). Not part of TC but emissions/distributor retard function.
Sounds like something that can be deleted
Yep. You’d have it still there with a 2 piece speedo and a the speed marker is in between the 2 cables at the t-case end. Can replace the whole thing with a 1 piece cable, especially if either of the stock cables are broken since I believe they are NLA.
If the existing cables are still functional, just unplug the wires. Believe the wires are blue/red and come out of the harness at the firewall right by the brake master cylinder warning wires.
Wow now I know what those 2 wires were for 😂 Just beware that 1 is hot when key is on. The nuts on the wiper arms you can get from McMaster Carr. I looked and my purchase history is gone they are a knurled type and a little larger than stock.
I had to have a speedo cable maker in Reno, NV make a 10" section for me. I ordered a Camry section hoping it will fit too!
I never knew one was hot when the key is on-good to know.
So here is the deal with the wipers. Because the arms have inset holes, a regular nut ain't going to work, knurled or not.
Something has to fit in there so that you can tighten the nut. Any ideas?
They look kind of like the valve cover nuts, but smaller.
I stole this pic from another thread.
In a pinch, or temporarily (or long term, who cares) you could use the proper thread coupling nut with a washer. Then you could get a wrench or socket on the end.
Part number?
Thread link:
Maybe part 9017606016?
I found a possible solution. Ordered a set of 4. will update on how they worked.
As I slowly and laboriously go through this process, I learn all sorts of things.
Today, perusing Cooler-Man's website, I discovered that I need to match the sensors (oil pressure and water temp) to the gauges.
I have a 1984 2F and my instrument cluster is a 1969. I believe I ordered the oil pressure sensor for a 1975, as neither engine had a functional one present.
How interchangeable are the sensors? Do they all just have the same threads, or is this going to be yet another overcomplicated mess?
I think they're interchangeable, the only difference is later models have an (additional) external ground tab as opposed to ground thru the body.
The oil pressure sensor is interchangeable. The temperature I don't think so. I used my original temp sensor.
I've also discovered an inordinate amount of yellow/red (Yellow wire with red stripe) in the engine bay side of the wiring loom.
According to my wiring diagram, yellow/red is only used in the fuel level and vacuum valve circuit. Going to leave the wire there, but not use it, in case I'm dramatically wrong about this.
Here is "the bible" of gauges and senders needed, should answer all your questions-
Dang, no Old Testament in that Bible 😂.
