[quote author=Stickboy
One other question... I've got a good 2F rad and wondering if there are any issues with cooling the 13bt with a rad for a 2F instead of fabricating a mount for the 13bt rad. It'd be easier to just bolt the 2f rad back in and fab some heater hoses. I wasn't sure if there was an issue with the cooling capacity being higher with the 2f and the motor running cooler than normal making the efficiency drop a bit since diesel's like a window of operating temps. Ideas?
Also, does anyone use electric fans? I know that they are common in most 4x4 circles but you don't see much mention of them by cruiserheads. To solve the boxing in of the rad since the motor sits back so far I thought a 24v fan would be the best solution; weld a fitting into the rad (any ideas of location since that seems to be a critical point) for a temp sensor for the fan and off I go.
thanks a bunch everyone,
-mike
Morning Mike,
you are just rocking right along. good to see the progress. the rad from the 2F will be fine for cooling the little 13BT. the same size cools the 3B, 2H, 12HT so you will be fine
i would run a custom shroud from the fan to the rad instead of the elec. as you can guess i am not a big fan of the elec. fans.
keep track of the hours, i will be interested in how long it takes a "newbie" to do the swap.
when you run the exhaust run 2 1/2" or larger with a free flowing muffler.
congrates on the progress.
Wayne
-mike
Morning Mike,
Wayne
