So here's the latest. not much. 2 sick little boys at home. my work schedule on the rig is at 9 pm when the boys go to bed, i drink a beer and go to the shop until 1 am.
i did finally get all the filter numbers and went to napa and am planning on getting the rig all lubed up and ready to go. found a bunch of 12v relays on
ebay in seattle to control most of the circuits.
Also talked to steve at backwoodsolar.com yesterday about a digital ammeter that'll measure both the current flow on the 12v side of the dc-dc converter as well as the direct 24v loads off the battery (a/c, glow screen, transfer). They have ammeter that'll do this with a 100a shunt and measure tenths of an amp and it has 2 separate voltage leads for 12 and 24 that if I SPDT switch them I can select between the two. all for $62. pretty slick deal.
I've stripped down most of the wiring after digging through the 3b online manual at birfield and the body/chassis manual. I'm down to about 8 significant wires and an unknown on one relay and plug I didn't label. PITA. Anyone have any idea of what the relay does that comes from the charge fuse and is actuated by a signal that ties to the 4wd indicator in the instrument cluster? Baffled. '
Cruiser_guy - i've done all the wiring so far on the bench (floor). it's been much easier to follow the wires this way and eliminate the unecessary ones. I tried in the truck at first but spent the 2 hrs or so and just ripped the harness out in one piece and layed it on the floor in the rough shape it was so my brain wasn't too confused.
I figure i have about 20hrs left. At the rate I'm going lately that'll be 2 mos. Hopefully i can pick it up and have the rig running in the next 2 weeks. Exhaust is still left, struggling with whether to bring it to a shop and have it done or buy a kit of tubes/bends and weld it myself.
Probably bring it to a shop....
-mike
