- Joined
- Jul 22, 2012
- Threads
- 581
- Messages
- 16,303
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
That's also a main cap.
Yes between the journal and bearing. Photos of #2 then 4. First one threw me cuz bearing got stuck to the journal by the plastigage and I had to gently pry it off w/ a wood scraper I made. Hmmm, am I reading this wrong? .025 is what I see...Sorry, just re-read your previous post and saw you already removed rod bearings to plastiguage them. Post up a few good pictures of the crank journals and the rod bearings. At >200k assuming it had oil in it you shouldn't have bottom end issues on these motors. I'm shocked that the cam bearings went.
When @Cruiserdrew refered to main bearings he's talking about the four big ones that hold the crankshaft into the block.
You said 0.025" on the rod bearings? Are you sure that wasn't 0.0025"? You put the plastiguage between the bearing surface and journal right?
Two photos of #2 and two of #4.Yeah, that looks fine. Put up a picture of the bearing.
Gotcha. Ok. Yeah that’s what’s in. I def noted STD on the two I had my hands on. Thanks.You’re going to have to measure the rod journals and determine what size bearings you need.
If your motor is original you will most likely just need STD. size, but you need to measure.
Very specific measuring tools correct?
