Where does this plug into
Las Vegas,Nevada
Where does this vacum port plug into?
A VTV, and thence to the choke breaker. Not needed unless you are doing a resto or a re-smog.
the choke breaker is a good thing if you ever plan on using e choke.
A 76 carb on a smog-legal US spec 76 2F engine?
It connects to the VSV on the fender well.
Desmogged?
Connects to manifold vacuum.
Desmogged & rebuilt by TLC Performance?
Connects to CB.
Yes 77 2F us spec.
Yes desmogged
Thanks! I connected it to the manifold vacuum.
What is a CB? and what do I do with that at this point?
Choke in the winter would be great.
I think this is what is being described above?...Pics from my first carb rebuild ('76) and installed to verify it would run on my '77 FJ40.
Oh, I'll take for granted that you have the vac advance on your dizzy hook into the egr cut port, as seen below.
HTH...
HTH...
I'm researching ported vacuum, for FJ60 distributor vacuum advance, for upgrading the ignition system in my Federal spec '76 FJ40 (11/75 build date). My carburetor has a port to the front of the idle mixture screw in the same location as shown in your photo immediately above. Where does the vacuum line run that exits the right side of the photo? To the distributor vacuum advance port?
FWIW - I purchased an '86 FJ60 2F to rebuild and install in my desmogged '77 FJ40.
'86 2F Engine
The final product:
There are only two vacuum lines on mine. One from the vacuum advance on my Trollhole Dizzy to the EGR Cut Port on my base of my OEM '77 Aisan carb. The other is from my choke breaker to manifold vacuum.....The vacuum hose spaghetti/smog mess is now residing in Cali.
I think I may have answered my own question. I'm assuming this is the same engine as in the photo above. I've been reading more about the EGR Cut Port as a source of ported vacuum but haven't been able to confirm this would be a good port.
Yes, that is the ported vac fitting on carb base. Connect it to a vacuum advance dissy. Do not connect to a vac retard dissy.
Thanks! I've got two complete kits for installing relatively low-mileage (125K to 175K) FJ60 distributors into my '71 and '76 FJ40s: distributors/coils/igniters/dented side covers/side cover gaskets/distributor covers (optional), plus new parts on order from American Toyota: distributor caps/rotors/dust seals/O-rings. Do I have to worry about venting the distributor caps once I'm done?
Good to know I won't have to modify the throttle body on the '76. The rest of the emissions system is intact and functioning, so I want to keep as much of that as I can. For the distributor vacuum can I tee into the line that runs from the port on the carburetor to the vacuum switching valve?
I know my '71 FJ40 carburetor doesn't have the vacuum advance port, so I'll plan on taking it to one of my local precision machine shops. I've got all of the pertinent information I've gleaned from posts here on MUD. I also have two spare carburetors of the same vintage as my '71. I might as well have all three modified at the same time, maybe I'll get a volume discount :-).
You don't worry about it, you just do it. Connect the small cap fitting to a barb on the air cleaner lid. Connect large fitting to a disposable fuel filter zip-tied at the top of the firewall.
Yes, that's the only option.
Thanks again - now that I know I don't need to modify the carburetor I might just have an upgrade in place before the end of the weekend.
