Builds What's a Parts Guy to Do?? (1 Viewer)
What Drew said.
I just put the whole (mated) shebang in myself this weekend, and it was a challenge -- and not very safe -- to do it alone.
Given your doc's orders, you should be sitting on a stool with one hand on the picker controls, the other around a Belgian (your choice on how to interpret that), barking orders at the hoi pollloi bronze class you have assembled like the philosopher king you are.
And I got a bit crazy with some other parts.
New reman Toyota starter (unfortunately remanned in the US).
And then a few other bits and pieces.... Since I am in the front of the vehicle might as well renew the headlight buckets, rings, springs and hardware.
I know, it's getting a bit out of hand. What can I say? It is an addiction after all.
Please put me down for "...the headlight buckets, rings, springs and hardware" if you would be so kind, sir =)
Shane
And would it be totally inappropriate to say, "I just nutted"? Apologies ahead of time =) Those engine pics = PURE PORN!!!
OK, I'm getting the feeling that this is the anti-thread of the "Ultimate 80 Series Parts Discontinued Thread" thread. You are searching for all remaining available 60-series parts and buying them.
THIS
is what is going to happen when you get very close to "done".
Your list will get smaller and smaller of things you gotta do.
You will double check everything you can three times, which actually means you will check everything 6 times.
You will still have that nagging feeling that maybe you installed the distributor 360º out when #1 was at TDC exhaust instead of compression. You'll know (think) you did it right, but "What If?"
You will think of some other little thing that needs to be replaced.
Your list will shrink to 1 or 2 more items.
You will then add a few more items to the list....
BECAUSE....
You will want to put off trying to start the engine "until tomorrow".
You will find some reason the next day to put it off "until tomorrow"
Then you'll look at your list and realize there is nothing left on it and that sick feeling of nervousness will rise up.
Then you'll think of an excuse to put if of "until tomorrow" again.
THEN
You'll say to yourself "This is ridiculous! What am I going to do... Never start the car again?"
So tomorrow will be the big day.
WHEN
Tomorrow comes you will walk out to the car with a nervous feeling, knowing that today is THE day.
You will remind yourself (for the 5th time) that your power steering fluid has been filled and the system is full of ATF and bled.
You will stick the key in the ignition and feel that sick feeling again.
You'll then say F#$K it and turn the key....
OF COURSE
You'll know that it won't start instantly cuz the fuel lines and carb are dry, but the racket of the starter turning over the dead engine will sound like mourning bells at a funeral.
So you'll turn the starter over a few times without pumping the accellerator to prime the carb. Then you'll walk back out to the engine and check to see if you can see gas through the sight window.
Then you'll see the gas in there when you look real hard and shake the car... and THEN you know the moment of reckoning has come. Oh god..This is It.
YOU
Will pull the choke, pump the gas, wait several seconds and then....... TURN THE KEY>
and BLAMMO!
It will spring to life! Holy S*&T!
Maybe a little rough the first few seconds and a little clicky with a couple loose valves, but man it's running! It's running good! And every neuron in your brain will be trying to calculate what is going on at that instant with the 1365 new parts you just installed in the engine.
You'll let it idle for a little bit and quickly run out and check for any big leaks or disasters.
You'll see what looks like way too much white "smoke" billowing out of the exhaust pipe, and you'll try to assure yourself that it is just water vapor and not coolant burning off from a botched HG install.
You'll then stop the motor after this short while to check everything.... and the most GIANT smile will come to your face.
You Did It!
Few things in life are as satisfying
Shane
DAMMITTT!!!!!!!! Looks like i'm calling Dan tomorrow to add to my order. It started with a call for $7 worth of body plugs to close up my rear heater delete (the cold will toughen my kids up)...i've now added a backup windshield gasket, door handles, front and rear wiper blades and wiper arms, couple of additional grommets for the rear hatch that i'd over looked before....now I "need" headlight buckets, rings, springs and hardware...and I have t plan a road trip to get new glass...just because I effin can. Must keep all receipts hidden. Heroin would have been a cheaper hobby to take up. BEER, I NEED A BEER (wait got one in my hand already).
It would be nice if the horns were still available instead of headlight buckets that can just take a shot of paint.
Dang Koito!
THIS
BECAUSE....
THEN
WHEN
OF COURSE
YOU
and BLAMMO!
You Did It!
Words of truth and experience.
Headlight bucket replacement may be a little excessive :D but replacement of the rings, springs, and screws is a good idea. Over time the hold down tabs on the chrome rings become tweaked during the course of headlight replacement and even here in the rust free South the screws become rusty.
You could have removed the headlight buckets and had them powdercoated the same gray color as the valve cover.
Man, it's getting so close.... I can feel it percolating. :)
Trying to decide whether to mate everything together and drop in or do the engine first and then get the tranny/xfer stabbed from below?
Thoughts? I hope to have assistance either way I go, just trying to think about the most expedient and least pain-in-the-ass method.
You've created a beatiful piece of art, Beno. Enjoying all the pics.
If your crane can handle the weight, assemble first then install, even if you are working alone. It's a pain to stab the tranny from below and more hazardous to fingers. Better to be above heavy things than underneath them.
Is that a gasket on the carb insulator, or just what the surface looks like when new?
Yes.
Don't forget to install the M8 studs in the manifolds for the intake side plate (EGR/PCV plate). When installing the EGR deleted side plate, there are also 2 short bolts into the intake toward the rear that support the PCV tube and the manifold temp sensor. Be sure to get a new temp sensor & nuts & pigtail and get it all installed before engine goes in the bay. It's a PITA later.
Also, don't forget to mount the throttle linkage bracket underneath the 2 outer carb nuts.
A quick tip to install tranny from under the truck. Buy a couple of bolts that are longer than the two bottom bolts that go into the bell housing, about and inch to inch and a half. Cut off the head and cut a slot into the end. Thread the bolts into the bell housing and use as guides to get tranny seated. Once the top bolts are installed use a screw driver in the slots to remove bottom bolts and bingo baby the bottom bolts go in.
15600-41010...
Santa came a little late this year, but the gift was priceless. Thanks Santa. ;)
Including my collection at home, I now have enough for the life of the 2F after rebuild as well as my 1FZ-FE. :)
