What is this on my starter, will it still work
Iowa
Hey just bought this after my other took a crap. Everything is correct, but this cable. What is it? Will it still work because the other didn’t have it.
- TOYOTA Calls that in the FSM and on the Microfiche a ROCK AUTO Connector ......
- Certain Modle Year land Cruisers have wire going from the ROCK AUTO Connector to the Ignition Coil
see my below Example of a NEW NON-USA High Heat Dissipation Saudi Spec. Starter COMPACT super HIGH Output Modle Example Photos for the F F1.5 2F and 3F and
3FE
Note the Black wire w/ red tracer Stripe :
LINK also :
3FE
LINK also :
So if I were to install it and not plug it in to anything would it operate like normal?
i will let @3_puppies and @65swb45 Take a WAG here , & help out answer this one , the TECH is Before my time in the Wild ..........
Yes
Typically, that 'extra wire' provides a full 12v to the coil only when cranking, vs. the reduced (8 volts) the coil normally sees after going through a ballast resistor. If the truck starts just fine without it, it's not critical. It's not applicable to all years of trucks, IIRC.
Others chime in if I got this wrong.
