What have you done to your Land Cruiser this week? (46 Viewers)
Finished up the wiring harness and everything works as designed! Lights, hazards, fan, wipers, directionals, everyting! I then went and installed my front axle. I Martacked the axles, rebuilt the birfs, and now just waiting for rotors.
I installed the rear 4" springs. This will result in removing the 29" highway tires for some 32" Super Swampers.
I'm on my way to garage to install the fronts.
Washed it today. Spent the last week testing out the newly installed 4" lift on whatever trail, fire road, mud puddle, etc. I could find. Stoked on the end result.
Geez did you put the lift on in the garage? Looks like your too tall to get out...
lift?
what setup did you go with?
Red Line rollcage installed
Justin from Red Line Landcruisers was here to install the cage he has developed. got it in, in record time. such an AWESOME product!!!!
Shhhhhh
Pulled Chia into the Garage - 1st step if frame off build. Will scrap the tub.
Helped a friend replace calipers on his chevy
Cleaned out the Garage... well tried to clear a path - Cruiser parts everywhere.
I went with the Safari 4.5" lift from MAF. It's still a little stiff, but I'm pretty happy with it so far. Definitely like the way it looks.
It barely makes it in the garage. I have to manually release the door and push it up all the way. Already s****ed the hardtop a couple times when I forgot to push the garage door up all the way. :doh:
i started pulling off parts to clean & repaint and started to replace some old nuts & bolts.
Restored oil pan, valve cover, replaced gaskets, changed oil
Tested dash components, cleaned connectors, replaced bulbs
Replaced window regulator and window
Added a hose from window wash tank to sprayer
Replaced thermostat
Restored heater with new paint and SOR Heater Restore Kit
Replaced heater core
Took it up into the mountains!
With the help of a bunch of Mudders I dropped into my Pig a rebuilt 2F, also a tranny and tcase, bolted up dshafts, installed radiator, new heater hoses, new Sag pump, reinstalled front bumper and 8274, installed new (booty fab) dual rear swingouts, extended breathers on tcase, front and rear axles and drank a bunch of beer - all in a weekend!
Pulled off the rear suspension, cleaned each individual leaf with the bench wire wheel, added the add-a-leafs, and successfully installed the greasable shackles & pins, changed all the fluids, and a new shift boot for the tranny tunnel tcase shifter. Next weekend: bleed hydraulic lines, adjust the brakes, new tie rod dust boots, install new speakers & stereo (will post thread :D ), new PCV valve and hose, and will fire it up after sitting all winter. TEST DRIVE!!
started fab up rear bumper hopfully finish it this week....hitch is comming off and a newer style reciever will be installed...and ice chest rack/jerry can holder
snapped the output housing on the t-case , ripped the e-brake cable off when the drum spun .
re-sealed the oil pan gasket , installed new speedo cable .
This week I recieved my newly machined transfer rear output housing and installed two new seals.
I am looking for a 'leak free' Cruiser! (although, I have several leaks to go!).
I will install this baby this weekend (after I wipe the dust off).
Installed rear seats, started on some body work. and started making a center console out of the stock center seat back.
kyle
Installed the roof rack 4 in Wilderness brand,home made rack tubes,put the hi-lift jack on the pass side( i love the look) installed a dual band antenna for a HAM radio.Hit some trails yesterday with the club http://www.xtreme4x4adventures.com/
I finished my PSC high flow powersteering pump install last night. :bounce: Checked all the fittings, tightened the belts, took it out for the maiden voyage. PS works great!!!
and then I snapped the rear driveshaft. Tore a U-joint completely out. :o I limped home in 4wd. Guess I know what my next project is. :frown:
