What have you done to your Land Cruiser this week? (49 Viewers)
And a few more
I kind of like the no hub cap look but will likely reinstall them
Once my rig is out of the shop, I am going to do the electrical work myself regarding headlights, brake lights, back up lights and turn signals--most likely bad grounds. I have been reviewing the electrical schematics; looks relatively basic by my eyes. BTW, I just realized that I should have started a separate "build" sort of thread instead of inundating this thread with my build; my apologies if this is not appropriate. Martin
Just finished up the hose installation for the new heater. The plastics company I contacted made two gray PVC "doughnuts" to adapt the smaller diameter outlet to the larger diameter stock defroster hose. They fit to a "T"! The owner of the company told me the solvents in the glue would react with both the PVC and ABS and would make a strong bond. I have to take his word for it. I scratched both mating surfaces, cleaned both and applied an ample amount of glue to both surfaces and held the "doughnut" on for a few seconds. Felt solid enough but I waited for a while to let the glue harden completely. Then attached the hoses which fit snugly.
@kbahus You asked for a photo from the side so here it is. I took the 40 out yesterday for the first time with the new rear springs and it rode about like I expected, a little harsher but not nearly the body lean I had prior with the stock springs in the rear. I can live with the ride and I am considering not having the front springs installed since it looks level, I put a long level on it and it was just about perfect.
@Martyt Thank you! The hot rod shop that did all the paint and body called it hot rod black which is just another way of saying semi-gloss black. Funny thing, the hood came out flat from the same paint batch. Don't know why but when they offered to repaint it I declined, I liked the contrast.
My rig has a large battery tray (not stock I get it) so I am going to run two batteries; one for the truck and other for a "portable" winch will be in a cradle that will hook up to my trailer hitch (but will be locked away in one of my Tuffy boxes when I don't use it). I have the PTO winch up front so I probably need another winch like a hole in the head but nice to have options and redundancy.
Dash refresh complete!
The picture is simple but represents a bunch of things
-Choke cable rebuild (@RAGINGMATT)
-Elimination of toggle switch and reconnection of carb cooling fan back to factory spec
-all knobs repainted and refreshed
-radio detailed
-CB bracket eliminated from ashtray(new ashtray faceplate)
-heater rebuild
-warn and unleaded fuel only decals
hOOter
@hooter nice work!!! Is that an original radio?? Very clean
Annual springtime oil change, filter change and lube. Only put 5200 miles on it in the three years I have had the GPS speedometer installed so I guess I never wear the oil out. Didn't put all of that in but have enough to use when it is time to top off the oil.
