What have you done to your 200 Series this week? (22 Viewers)
No need to post across multiple threads and certainly no need to start replacing parts just yet. Pull the plastic kick panels and look for signs of water getting into your plugs. Almost all electrical problems on this series seem to come from water getting into those connectors. If you find that water has been there, you need to start looking for how it got there (blocked sunroof drains, improper cowl sealing after windshield replacement, etc.). There are tons of threads on here about this.
Loncky steering wheel cover
I installed a Grom VLine 2 in my 2008! Installation was pretty simple, and I’ve been very happy with the results. I’ve read some mixed reviews, so I am relieved by how well it works for me. I ended up placing it in the top half of the glovebox since I figured I’d want to access it often, but if it continues to be this solid I may move it somewhere more hidden.
I also added a 360mm convex Broadway mirror. So far I enjoy being able to see my passengers and cargo, and there’s a bit of coverage on the passenger side blindspot (though, not obvious in this picture). I am planning to experiment with some different angles. Being able to see yourself is definitely unusual, but it doesn't bother me much.
Looks fantastic! Is that LRA's gullwing? Interested in your thoughts on it..
It is not. I believe LRA’s comes from The Cruiser Company, who built my rear bumper. This one is from Emuwing. I prefer the frame on Emu’s vs TCC, and they offer it in tempered glass, which is what I have. I absolutely love this thing. I only did one side because I wasn’t sure how it would turn out or if I would like/use it all that often. Since the swing-aways went on, I use it a ton and will be doing the other side before long. I can even speak to build quality, as I have accidentally left this open up to highway speeds with no damage, though I wouldn’t recommend purposely doing that 😂. Install is a little involved, but once you’ve done it, the other side will is a cake walk. I did need a little paintwork done. In the window sill, with the frame in place, there was an area where the factory adhesive would still be visible and would NOT come off, even with an eraser wheel. I’ve since learned this is pretty common. Really not a big deal though, I could have done myself if I didn’t already have a good, fairly reasonable, paint guy. 10/10 would recommend if it interests you.
Thanks for the details! Interested for sure..
Added a Tritium tube to the overhead light switch to find it in the dark.
Added Baja Design S2 Pro light pair to rear cross member, adjustable. Will use as chase lights, camp scene lights and reversing as needed. They are connected to Switch Pro in sunglass holder and can be dimmed as needed and operated from phone while at camp.
Also, not too exciting, touched up underbody with Corrosion Free to prevent rust from treated roads.
I have mine mounted in the same position, unfortunately I do get a shadow to the rear from the spoiler.
  • Back
