What have you done to your 100 Series this week? (10 Viewers)
I recommend the Weathertech mat to go with those seats!
That was the first mod!!
Also have a seat protector under the seats. These seats are the upgrade from the infant carriers.
Replaced 14 year old headlight assembly. Old glass was still in good shape but inner reflectors were severely oxidized. New light output is amazing!
Old
New
Old
New
That difference is actually stunning! Very impressed with the results! My inner reflectors were getting pretty crappy too so I just pulled the trigger on an HID retrofit and I'm fairly pleased with the results as well. Just needs some fine tuning that I've been too lazy to do.
Just put some 2013 wheels on my 1999 I think it look great pics to follow.
That does look great! Did you just repair the reflectors and inside of the housing, or did you replace the entire assembly? What source did you use if you don't mind me asking?
Thanks!
I replaced the entire assembly. Purchased them from Toyota of Dallas with a TLCA discount. I also adjusted the lights up about an inch (marked wall, from 10' away) which helped the light pattern too. So far no one has flashed me.
Looks great! I'm prepping mine for paint right now
I wasn't sure that I would like having the lugs still be chrome, but truthfully I don't even notice. It also makes the running boards look better. Have to keep those until I can get the sliders fabbed up...
Got all of the components to build my Ram iPad mount:
I hope you have better luck with the Full size ipad and the x-wing than I did. First washboard roads I hit the thing kept popping out. When to an otterbox cover with a lid and screwed the lid permanently to the x-wing main part. The otterbox lid does a better job holding the ipad in its case than the spring clips. So I took them off next...
And a bag of chips, as the saying goes!
Do you get much bounce with the dual cups? I run a single cup but use an articulated arm (3" + 8") with a furniture pad on the 8" to allow it to rest on the dash for stability.
OregonLC- I'm using the dual cups with a 8" arm. I initially tried using the setup relying on just the suction cups but it bounced too much. I ended up using a piece of foam between the 8" arm and the dash and it works perfectly. I tested it out over washboard terrain and it is VERY secure.
I have heard that there were issues with the original x-wing that RAM offered. The current setup is very robust and it worked flawlessly on rough terrain over a two day trip that we just finished. Do you have pics of your setup?
Bought Monday. Wheels & De-gold Tuesday.
I just picked up my drive shaft from the shop.
.138 DOM outer wall :). I'm going to have fun trying to bend this one!
How much more does that weigh compared to the original?
Finishing painting the wheels, got the sliders on, and started the sound deadening install.
Started AHC removal, installed OME 2.5 inch heavy lift in rear. Turns out, that's an ordeal for someone of my limited abilities. Of course, muffed the coordination of the washers on the shocks and will get to pull and reinstall shocks tomorrow. At least the top nut won't be recessed like the AHC rear shock nut was.
Finished the AHC delete. Finished the 2.5 inch OME lift from Slee, including diff drop. Installed Metal Tech sliders. Put on some 285/75/16 Toyo Open Country AT2s. This thing is a different animal.
