What have you done to your 100 Series this week? (56 Viewers)
It would be an interesting experiment as ATRAC and OE locker never coexisted. However, I would think I would be moot; locked is locked. It may, however, change how ABS reacts. And VSC wasn't until after locker either.
I still think pairing left/right channels is your best bet. No codes, just as easy to switch on/off. The only deal killer would be if running both feeds off a single sensor would create an impedance mis-match.
I loaded my hundy with all of my 100k oem pm parts from CDan and Beno.
New radiator
Fan bracket
Water pump
Thermostat
Plugs
Fuel filter
All tensioners
All idlers
Drive belt
Timing belt.
Fan bracket
Fan clutch
Radiator hoses
Fw heater hoses and t's
270 amp alternator (NOT OEM) DCPOWERINC
Assorted seals and o rings.
New rad cap.
Can't wait to get this stuff off of my list. I have been collecting parts for a year plus. Already have new air filter, o2 sensors, pcv and gas cap installed.
I am also having the trans pan dropped for a full fluid change. (Diffs and tcase have already been drained and filled.)
Trying to get the baseline done to take my sons down to Albuquerque for a camp out and to see the balloon fiesta.
Dipped the rear badges black. Left the emblem silver to match the grille.
Looks like the wax didn't t work, you still have dents. You need some band aids.
1. bought it! 98, rear locker, 150k
2. removed running boards
3. measured ride height, gave the torsion bars a crank or 3! gained a little lift
4. made a plan to make some sliders
5. tried to get it stuck(couldnt)
6.removed rear carpet and rear trim to clean
7. removed peeling wood trim
Welcome and enjoy!
Got one of these a little while ago . . .
Some of the goodies are starting to arrive.
try two.. its utterly embarrassing.. you should be ashamed for using your cruiser in that way
Fixed tree damage from dickey bell. Pretty close. Needed a turn signal. Lots of sheet metal pulling but pretty straight.
Nice, I can't tell you how many times i've looked and those and thought about putting one on my rack.
Thanks! Actually I think I came across one of your posts over on EP that pointed to it. After researching for a long time and coming across your post, I decided to pull the trigger.
The inside isn't powder coated and it doesn't have the gas strut like the old ones, but figure I can address both of those later.
