What have you done to your 100 Series this week? (34 Viewers)
Oil Change
Just your typical DIY oil-change, made more fun by the knucklehead at the dealership who decides to be helpful and install the oil filter with an impact wrench [or similar].) :censor:
For tech content: yes, driving a screwdriver straight through the side to twist the filter off worked -- even thought access was a pain with my armor.
(I normally do all my own oil changes, they just happened to do it as part of the 90k service at the Lexus dealership--and this was my first oil change since.)
Tire rotation and road force balance yesterday.
Pristine Clean and Leatherique today, and tomorrow and maybe Tuesday depending on the results...
- Swapped rear rotors for OEM fresh
- New pads all the way around
- ReGreased drivers side hub... Passenger will wait since it took me three times to get it right so that the snap ring would fit.
- Greased spindle
- Tore wheel and flange off to install the flange gasket since it was found during clean up
- cleaned MAF and TB
- Checked axle vents
- Installed ScanGauge II
- Shot grease into drivers side ball joints with grease needle given leaky boots
- Tore off factory roof rack
- Assembled Front Runner basket
- Stripped nut when installing tracks - seeking out either drill/tap or helicoil solution
- Tried to trace down knocking sound from rear with no luck
To do list:
- Fix stripped bolt
- Lube drivers side hub
- Swap OME 865 for 866's
- Cycle some new trans fluid
- Oil Change
- Reinstall gear and pack up
Departure for Ouray in 16 Days!
Repainted my scratched wheels. Gotta love rattle can. Bumpers, sliders and skids are next.
Much better than taping, wish the rest was that easy.
nice, i love how u did the maskingg, :cheers:
I plan on masking my side molding in a similar fashion, so much easier than taping really close, and you can still put the painters' tape and plastic sheeting on the cards for masking larger areas.
This weekend, I thought the rear of my center console was toast including the cup holders. I was able to disassemble it completely, clean it thoroughly and managed to get it all solidified into one working mechanism with some new screws and finesse. Was almost going to pay a few hundred for a used unit, but this could not have worked out better. I spent $0 and only my time :D
Trying to find time to get everything installed/maintenance performed and ready to go to Ouray!!
13 days and counting!!!
Changed an 02 sensor. Check engine light has been on for almost a year, and the replacement sensor had been sitting on my dresser fro 6 months. It took me 30 minutes to change it. And that was basically one handed since my skid plate was in the way! It's always the simple stuff that takes the longest! I also finally unplugged my ASC computer...no more blinky lights! Still need to find a good route for the CB antenna cable. A cheap and quick way to mount the fridge for Ouray. MAybe change the oil before the trip too!
Mr. Bubbles - at 235,000 - received new starter contacts and plunger.
Don't believe the parts guy when he says they never replace the plunger. Added three days to the project waiting for that lil' item...
Since we had to wait on the plunger, also replaced the O-rings, gaskets, and insulators for all eight of them injectors.
Got to enjoy some quality time with my daughter - home for the summer from TCU - while she did an excellent job assisting and encouraging.
Sent from my iPad using IH8MUD
Did the same to mine...what a "PITA" it was, but looks much better than that fake wood.
OME 2 inch lift, slee diff drop, new axles...and a dent in the bumper from wheelin!
Group 31 tray from Slee and Die Hard battery installed. Hopefully no more dead batteries!
Well I finally managed to do some work on the cruiser today in preparation for the road trip to Italy.
I managed to get the AC tested and as i thought it has a number of leaks in the line going to the rear so out it came in bits and pieces and i will post the two ends off to get a single flex line made up.
Thanks to Marius who gave me the idea for installing a fridge as the center console.
The fridge is a Waeco CDF-11 for those that are interested.
After stripping out the center console you left with this
Then removing the base plate and a few other small bits you end up with this.
A bit of 10mm ply, some contact and some rubber mat and i ended up with a base plate
The base plate bolt into place like this
Prior to bolting it in i thought i would show you how it fits the fridge and the strap to hold it in place.
It fits very nicely and even looks a bit OEM if i say so myself
Plenty of leg room still
For the mean time its just plugged into one of the cig lighter sockets until i work out how best to power it long term off an aux battery.
It does have an auto cut out if it senses your battery is low and they are pre set too either 10.1 or 11.4 or 11.8 and then it auto starts once it senses a charge.
I let it run with the car idling for 45min set to -18 with an ambient of 28 and the water i put inside was ice cold and much longer would have froze.
Im very happy and will report back after the trip on how it behaved.
