Got a photo of the “broken connector” in question?Bought a 2000 with 480k on her. Cleaned up the AHC switch that wasn't working, installed fumoto drain valve and changed the oil, replaced some bulbs, figured out what an aftermarket switch does (previous owner didn't know), got techstream and adjusted torsion bars trying to get everything straight, and found a broken connector for the back right globe so now I'm here to ask for some help on it.
Appreciate all the work documented here, it's been great figuring everything out and I'm happy to own a 100!
Yes! I posted a thread about it. Basically I pulled off the protector plate, straightened out the pins and tried to reattach for now. I'd like to properly repair it, but not sure what exactly to do. The AHC works like it should, except that the back right( broken connection) sits about 1" higher than spec, when everything else is in spec. Not sure if I need to replace the whole thing (what exactly I need to replace) or if it's a simple repair.Got a photo of the “broken connector” in question?
Did you get some of these for the rear seats also? Interested to see some more photos if you did. They look like they turned out/fit pretty niceFinally put my MW brothers seat covers on. Great option for some tired seats without doing a full upholstery job. Really happy with the quality and fit.
A $100 Seat Jacker kit wasn't in the budget so after a couple different approaches to lifting the front of my driver's seat this was the one that worked. About 6-8mm of lift and the bolts are long enough to add a couple more washers if I wanted to. Not fun wedging my hand under the seat because I couldn't figure out how the front plastic trim cover comes off. You can see in the side picture the old max height spot vs where the seat is now.
Just some regular washers is all I used. The stock bolts that go in that location are a lot longer than they need to be are are long enough to safely accommodate the washers I added. Going to take it on a 40 mile drive later today and I'll see if what I added was enough or if I need one or two more to be ideal.Nicely done! Just washers/spacers and a longer bolt where the bottom cushion mounts to the frame?
Pics?Finished the wrap!
License plate light - LED License Plate Light Universal - https://www.ruffstuffspecialties.com/R2217.htmlInstalled the 3rd row AC redirect from Cruiser DM and it works great! Passengers love it especially the unlucky middle seat.
Had to re relocate my license plate camera since I got a swing out carrier from 80%offroad. I cut it into one piece rather than having the rectangle shape and mounted on the lower bumper cover held on my nuts/bolts and topped off with silicone.
Got pulled over at night (just a warning) for not having a light on my license plate so I installed this Amazon battery solar light thing. Works well but the only downside is having it on all night since it senses the dark. I can switch it off but I know I'll forget to turn it back on.
Rerouted my plug for android auto because it was wired stupidly under neath the steering wheel and kept tickling my leg. Put it underneath the coin tray next to cigarette lighter. It doesn't close all the way but it works for me.
Next on list is trans drain and fill, reindexing the torsion bars, and the dreaded front diff bushings along with the diff drop. Almost dropped the money on diff cover to avoid the bushing removal but I just did fluid change on everything. View attachment 3347721View attachment 3347722View attachment 3347724View attachment 3347725View attachment 3347727
